Thread: Returning to my property/pool after renting the property out for 2 years
    Apr 2011
    Palm Harbor, Florida
    90
    I don't have TFTkits with me anymore - already ordered one yesterday! But would like to see what I can do now while the test kit is on the way.
    Took sample of pool water to both Leslie's and Pinch-A-Penny (yeah, I know.. "pool stores lol"). Did both to ensure I can see what's close to reality (if there's some degree of consistency between the 2 results) and what's way off (mis-measured at one place possibly).
    Leslie:
    FAC, TAC both 0 (yeah, bad)
    Salt level: 2300 (although my SWG is reporting 2700-2800 at the moment)
    CH: 260
    CYA: 10 (yeah, too low)
    TA: 60
    pH: 8.0 (high)
    Phosphates: 200 ppm (high)
    Pinch-A-Penny:
    FAC, TAC also 0
    salt level: did not measure (they thought I had chlorine pool, not SWG)
    pH: also 8.0 (high)
    TA: 80
    CH: 400
    CYA: 20 (also too low)
    Been a while, I'm rusty w/pool chemicals, help me out - I know I need to fix CYA, pH, and have SWG generating chlorine again for pool - what do I start with? Shock (to add CYA)? Add salt? Fix pH levels? What are the first steps here in bringing my pool back to normalcy gradually? I know this is going to be a multi-step thing, I'm not sure which one is priority right now. Thanks in advance!
    Florida-style enclosure (lanai) housing 18,000-gallon outdoor in-ground salt pool/spa, PeebleTec finish. Spa water waterfalls into pool. Hayward model 17502 cartridge filter system, Hayward SP3400VSP EcoStar Variable-Speed Pool Pump. One skimmer, Baracuda Zodiac MX-8 cleaner. Palm Harbor, Florida
    38,268
    Re: Returning to my property/pool after renting the property out for 2 years
    I would not worry about the SWG at this point.
    Get the pH down, Get the CYA up to 30ppm, and then follow the ShockLevelAndMAINTAIN Process.
    Once the 3 criteria are passed to stop the SLAM, raise the CYA up to 70-80ppm, raise the salt level and get the SWG running.
    Mar 2015
    South Texas
    411
    First thing is to lower PH to 7.2 and then begin a SLAM. For a CYA of 20, your shock level would be 10 but pool stores get the CYA wrong all of the time.
    If I was you, I would just pour a jug of bleach in once a day until your test kit arrives and you can do it properly
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Apr 2011
    90
    Thank you both!
    I'm trying to find what I think is/was a sticked post/thread on cheap equivalents that one can buy at Walmart or grocery stores (like using bleach instead of liquid chlorine, using baking soda instead of "soda ash" at pool stores, etc). (edit: found it here - Pool School - What is TFPC? )
    Want to make sure I buy a couple of jugs with correct bleach type (if there are multiple kinds) - also, what are the customary jug sizes to look for when doing SLAM method? 1-gallon jugs? (edit: previous tenants left a partially used jug of clorox so I went ahead and poured that into the pool just now. Will either buy liquid chlorine at local pool store or jug of bleach at Walmart for the subsequent days).
    38,268
    Most bleach is no 8.25% in 121 oz bottles. Or in the pool areas you can find 10% in 128oz jugs. Or at some pool stores you might be able to get 12% in bulk jugs.
    This might have more of the information you are looking for:
    Recommended Pool Chemicals
