Thread: Sta-Rite impeller seal replacement
    May 2008
    Des Moines, IA
    16
    I have a Sta-Rite JWPA5EL-2A pump with AO Smith motor and a leaky impeller seal. I've obtained the new seal but can't figure out how to get the impeller off the motor shaft to get at the seal. The store where we bought it "thinks" it's left-hand threaded onto the motor shaft, but can't get it to unscrew. Does anyone have suggestions for how I can do this without destroying the impeller?
    Inground 14'x28'x4' flat bottom kidney Vinyl
    Dynamo 1hp - Pac Fab TA-40 Sand filter 1-Skimmer 2-Jets 1 bottom Main Drain
    10,500 gallons
    Aug 2007
    near the swamp
    806
    Re: Sta-Rite impeller seal replacement
    On the back of the motor is a slot for a slotted screwdriver on the end of the shaft. You may have to remove a rubber cap to get to it. Slide the screw driver into it and spin the impeller counter clockwise, and it should come right off. What also works is a pair of small vise grips right on the shaft in between the pump housing.
    May 2008
    Des Moines, IA
    16
    Thanks. It's exactly that way. Unfortunately the impeller was stuck to the shaft so tight I had to break it apart and pull out the pieces, but a new impeller and seal are still abut 1/4 the price of an entire pump.
    10,500 gallons
    Aug 2007
    near the swamp
    806
    Your welcome. I do this stuff all day, everyday.
