Thread: Aiming of the old pool returns
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Hello, I am trying to figure out the best way to aim my pool returns to keep the pool as clean as possible. My main drain is plugged. The pool is 16x30 at its widest and longest points. The deep end is about 9 feet deep. Currently I do get debris stashes in the deep end at the bottom of pool underneath the skimmer. I have jet 1 pointed towards the bench on the right hand side of pool just below the surface. I have jet 2 pointed towards the left but maybe should point it towards bottom of pool, the deepest part.
    Please see attached
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    Jun 2014
    15,178
    Re: Aiming of the old pool returns
    The jets help not only with chemical mixing, but water surface movement back towards your skimmer. We like to get stuff pushed to the skimmer before it sinks if possible. You can try tossing a few ping-pong balls on the water to see how well they move around. As long as the prevailing winds aren't overwhelming your test, you can get a good idea of how stuff is floating towards the skimmer.
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Ping pong balls, or a grandkid's collection of rubber duckies, lol
    Mine is shaped similar but two skimmers. While you try different things to see what works best I think I would start with jet 1 as far to the right as you can get it towards the steps (not that you can get it quite that far) and create a clockwise surface movement. Jet 2 pointing almost across but aimed just to the left of the narrow point in the pool to also create a clockwise movement and carry things to the skimmer.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
