Thread: staining deck
    Sep 2015
    Rome, NY
    363
    staining deck
    I have a new section of deck, pressure treated, that needs (and I started) sanding of each screw hole (wood was too wet from what I understand). So of course those areas now appear lighter than the board itself.
    I have accepted the fact that the old and new decks won't match (using the same stain) but will these freshly sanded areas look the same as the surrounding board? If not, what can I do?
    I won't even ask what is the best deck stain....opinions are like...........
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Sep 2015
    Rome, NY
    363
    Re: staining deck
    Anyone?
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Re: staining deck
    It probably depends on the type of stain but my guess is that if it is a semi transparent stain then there will be a slight difference in the coloring between the sanded areas and the rest of the wood. The biggest factor is how long had the wood weathered before you sanded it? Sanding opens the wood grain so it is going to absorb more stain than wood that has weathered some.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: staining deck
    When making furniture it is typical to use a sanding sealer or pre-stain wood conditioner to eliminate a blotchy or uneven finish. I don't know if there is such a thing for decks. Maybe find one of the more experienced folks at Lowes and see what they have.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Re: staining deck
    If the PT wood is new and still wet, I doubt you will even notice once it drys out in a few months.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Sep 2015
    Rome, NY
    363
    Re: staining deck
    Thx. Will sand ASAP so it can weather together too.
