Results 1 to 8 of 8
Thread: Vacation for a week without running pump: what to do?
    Aug 2015
    Potomac, MD
    92
    I'm going on vacation for a week and won't be running the pump because the pump is hard wired to a fuse box so I can't put a timer on.
    Advice on what I should do before I leave? Put in tri-chlor pucks? What should I raise my FC to before leaving? Shock level?
    Outdoor concrete pool, 14,000 gallons, Purex Triton Clean & Clear Plus cartridge filter.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Vacation for a week without running pump: what to do?
    I would raise to close to shock level. If you have a floater, you can put in pucks based on your CYA level in pool math. I assume you dont have anybody that can help while your away.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Aug 2015
    Potomac, MD
    92
    Yes, I have two floaters. I'll raise to shock level and put in pucks. I must get a lot of sunlight. Even with the pucks in, my FC drops from 4 to 1.5 every day with CYA at 32.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    I believe I would just let the pump run.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Without circulation from the pump, the floaters will not distribute chlorine. It will just sit in one spot, and if it gets stuck at the side of the pool the concentration of chlorine could leave a bleached area on the plaster. If you do not have a heavy debris load you could leave the pump running and use the floaters. Otherwise raise the pool to shock level and run the pump for about 10 minutes before you leave. If you have a solar cover you can put that on to minimize chlorine loss.
    Love TFP? Become a
    TFP Supporter!
    Aug 2015
    Potomac, MD
    92
    Thanks. I don't mind leaving the pump on 24/7 for a week, but am concerned that it may do extra work if the skimmer basket and leaf catcher fill up. I suppose I can take the risk.
    Jul 2015
    Central Valley CA
    1,107
    I would defiantly leave the pump running may cost a few dollars more in electricity but cheaper than slam not to mention the work if you do have to slam. If you have a main drain and the skimmer fills the pump won't work much harder than normal, as the skimmer fills the MD flow will increases to compensate for the restriction in the skimmer. One of the few times the MD will actually do some good.
    What I would do is use a shim, stick, or weight to pin down the weir or remove it all together if that is easy to do. That will almost completely eliminate skimming and keep the basket from filling.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Aug 2015
    Potomac, MD
    92
    Thanks for the advice! Will do!
