Results 1 to 10 of 10
Thread: Why is TA rising?
    Oct 2015
    Orinda, California
    56
    Why is TA rising?
    What causes TA to rise? Fill water is 30. My PH from fill water is approximately 8.0 to 8.5. Thanks in advance.
    I get TA down to 70, but keeps rising.
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Why is TA rising?
    TA will only rise from a chemical addition. Either from fill water or a product being used in the pool. How are you chlorinating the pool?
    Isolated Spa - 345 Gallons
    Oct 2015
    Orinda, California
    56
    8.25% Clorox. approximately 121 oz every other night.
    Dolphin Deluxe 4,
    Oct 2015
    Orinda, California
    56
    I believe you are saying my TA should stay constant, if one is not adding chemicals. I have to lower PH now as my fill water adds to my existing range of 7.5 to 7.8
    Lower PH by acid.
    Dolphin Deluxe 4,
    Feb 2014
    Central Minnesota
    5,080
    It should stay constant under normal conditions until you add acid. Adding acid always lowers TA.
    Your plaster is old/fully cured, so there is not much reason to believe that you could be leeching alkalinity from your pool surface itself. If you could post a full set of test results, that might be helpful.
    Oct 2015
    Orinda, California
    56
    CYA 30 -35, very subjective
    CH - 310
    FC - 6
    CC - 0
    TA 7 goes to 8 in one week after adding fill water in the summer
    PH - 7.5 - 7.8, once rises above 7.8, I lower to 7.4, about once a week
    When I add acid to lower PH, TA also gets lowered to 7
    Dolphin Deluxe 4,
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by TJTJ View Post
    TA 70 goes to 80 in one week after adding fill water in the summer
    When I add acid to lower PH, TA also gets lowered to 70
    Corrected your numbers. I think you are posting drops of R-0009 without multiplying by a factor of 10.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Oct 2015
    Orinda, California
    56
    You are correct. I meant TA is 70 or 80
    Dolphin Deluxe 4,
    Feb 2014
    Central Minnesota
    5,080
    If your TA is increasing after filling, it has to be coming from your fill water. Have you retested the fill water? Let your source run for several minutes, then collect a sample.
    Oct 2015
    Orinda, California
    56
    I tested twice and the results came up TA 30 both times. I didn't let the hose run, almost immediately I filled 3 gallon bucket. Will do as you suggested.
    Dolphin Deluxe 4,
