Thread: Rock overflow STOPPED!
    Jun 2016
    Frisco, Texas
    2
    Hey everyone, I'm new here so please be gentle. I got my pool acid washed a couple months ago and ever since the rock overflow feature has not worked. The overflow/ waterfall from the spa to pool still works just not the rocks around the edge. Any suggestions?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,812
    Re: Rock overflow STOPPED!
    Have you checked all the simple things first like a valve you may have missed? Did the company who did the acid wash put a plug in the outlet of the water fall to keep the solution from getting into your plumbing and forget to take it out?
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2016
    Frisco, Texas
    2
    Thanks, it was a valve that was closed. It was a manual valve (didn't even know it was there). Problem solved!
