Thread: TA recommended level question
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    For an inground concrete pool, why is the recommended level of TA 70-90 when using bleach and 100-120 when using Trichlor?
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Re: TA recommended level question
    Trichlor is acidic, and is constantly lowering both the PH and the TA. In order to keep the PH from falling too quickly the recommended TA level is higher.
    When using bleach, which is PH neutral in the long run, the dominant effect of TA is to slowly push the PH up as CO2 outgases. To minimize this effect the recommended TA level is lower.
