Results 1 to 8 of 8
Thread: question on liner issue
    May 2008
    Jackson, NJ
    38
    I replaced my liner on my above ground pool at the beginning of last summer. We have had the pool for 8 summers and I was tired of refilling the pool from water draining out over the winter. This May I opened up pool and water was again down to a 1/3 of the pool and spent a day refilling with a garden hose. I was disgusted because between new liner and installation it cost me about $600. As a note my neighbor across the street has the exact same pool bought the same replacement liner used the same installer and his pool water level was the same as when he closed it last fall. As of now the pool level water is fine. My question is come the fall or now what can I look for leaks. I don't see any with the naked eye. Any advice or just deal with filling the pool back up every spring. The leak or leak is not impacting levels now but over the course of a long fall/winter it does.
    thank you
    AGP Vinly Liner 18 Ft Round
    Proline Cartridge Filter
    7600 gallons
    7600 gallons
    Casey's Avatar
    SW PA
    10,450
    Re: question on liner issue
    Do you have a solid cover? Because if you do and you let water accumulate on top of it, that rain water presses down on the cover and raises the water in the pool to spill out the return. That is where you are losing your water from.
    As far as your neighbor goes, if he's using a mesh cover, all that rain water is going back into his pool. If he's not using a mesh cover, maybe he's draining the water off his pool more than you are? But what you are experiencing is normal for someone who winterizes their pool for months. I deal with it every year.
    It would help if you add your general location to your profile so we know where you're from.
    May 2008
    Jackson, NJ
    38
    Thank you for the reply. I live in New Jersey. I do use a solid cover. I disconnect everything and plug return and intake as well as skimmer opening. I am diligent on pumping water off cover. I was even out in middle of winter clearing off snow and ice right after big blizzard we had in January. My neighbor has same cover. I know it's perplexing.
    7600 gallons
    Jun 2012
    western NY
    1,560
    What do you use to plug the openings with?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2008
    Jackson, NJ
    38
    I use a square foam item I bought at pool store for skimmer. I also have a plug got at pool store for return but I also drop pool level right below skimmer.
    7600 gallons
    Casey's Avatar
    SW PA
    10,450
    My dad messes with those plugs to save trucked in water and he has to truck in water every single year that he's had the pool since 2011. My brother also plays with those gadgets and he's had to replace water too. Me? I don't mess with it. I just fill the pool back up. I lose a foot below the return every single year. It's normal loss in my opinion.
    May 2008
    Jackson, NJ
    38
    Your probably right. Thanks for all the replies.
    7600 gallons
    Jun 2012
    western NY
    1,560
    Probably leaks past the foam thing. Look into an Aquadoor. I have used one since I put my pool up and every year I have lower my water level a bit.
