Thread: "Slider" broke on Automatic Pool Cover - need wisdom
    Jun 2016
    Livermore
    18
    Hi ya folks! First time posting to this forum. Hoping somebody can help me sanity check a problem that just happened.
    We have a rectangular pool with a canvas "automatic cover". There is a plastic "slider" that is on the leading edge of the cover attached to the track and the boom. One of those just snapped last night after the cover rolled over our bromine floater and got jammed up.
    Anyway, I'm wondering how difficult it is to replace the slider. From what I can tell, the slider seems to be designed such that the rope moves through the slider. In other words, the slider just doesn't push into the track it appears to be fed down through the rope and onto the track.
    Do I have this right? I'll try to attach a picture of the non-broken one, but it's difficult to tell how the slider actually attaches to the track from the photo. The broken one still has a piece inside the track and I can slide it back and forth but it won't come out with pliers. This is why I believe it to be somehow attached to the rope.
    I suppose a more generic question might be: does anybody have any experience replacing these sliders and -- if so -- can you share some thoughts on what is involved?
    I'm not the dumbest guy on the planet and I do have some mechanical skills, but I wasn't sure I wanted to take the entire cover off the track to replace this. Was considering calling a service, but thought I'd try here first!
    Many thanks!
    Casey's Avatar
    SW PA
    10,461
    Re: "Slider" broke on Automatic Pool Cover - need wisdom
    Welcome to TFP. I am not well versed with this but we'll get you Bumped to see if someone can help.
    Jun 2012
    western NY
    1,562
    Not really sure of what I am seeing in the picture
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2016
    Livermore
    18
    Let me take some better pictures with some context. I was a bit concerned about dropping my phone in the pool when I took this one!
    wjr75's Avatar
    Jun 2013
    IL
    836
    I think the slider is just bolted on. You should be able to lift it up and out of the track. Looks like they also have a screw through the fabric attached to the slider. Mine has two screws holding on to a bracket attached to my cover.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
