Results 1 to 16 of 16
Thread: Liner staining Possible Mustard Algae
    Jun 2016
    Freehold New Jersey
    14
    I just recently join the board after reading great advice I just repaired my PCB Aquarite SWG delimiter with an excellent thread !!
    I have a 9 year old vinyl line in ground Foxx pool with DE & a SWG system, 28k Gal located in central NJ. The property is covered by large oak trees.
    This is my first major problem so far (See attached pic) I have brown stains on the sides & floor
    The stains can be removed with a brush & when removed it looks like Iím scraping sand off the liner.
    Pool store states is mustard Algae. With the Salt system the water is balanced & I usualy do not add algaecide.
    I did the Vitamin C test on a small & the stain removed . Instruction are to reduce the PH ad CYA & 2 bags of Burnout73
    Then I should to add 43 OZ of Saltscapes Algae remover
    Thoughts, comments IS this the correct diag?
    Readings from a Bio guard pool store test system:
    TDS 4500
    Cya 29
    Tot CL 2.2
    Free CL 1.6
    PH 7.8
    Tot Alk 111
    Tot Hardness 187
    Salt 3100
    Copper 0.6
    20x40 28K Gallon IG Foxx pool, Vinyl DE filter, variable pump, 400K heater, Aqurite SWG (2012 Installed) all Hayward branded Built 2001. City Well water Aquanaut 400 suction cleaner. 12 Mil solar cover, TAYLOR K-2006 Test Kit Artesian Piper Glen Spa
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Liner staining Possible Mustard Algae
    A successful Vitamin C test usually indicates a metal stain. A chlorine tab sitting on the stain and lifting it will mean an organic stain.
    Those test results look familiar. CJP on Rt 9? Dottie help you?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2016
    Freehold New Jersey
    14
    Yes CJP Dottie did help However there are alot of opinions on pool stores disgnosing problems.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you check out Pool School starting with the ABCs of Pool Water Chemistry and get yourself a home test kit, you can begin to take care of your pool.
    Pool store testing is generally not worth the paper it's printed on. A quality, home test kit with Taylor reagents such as the TF-100 from tftestkits.net or K-2006 is needed to properly maintain your pool. Home testing is more accurate, more convenient and doesn't come with a hard sell for chemicals that generally accompanies pool store results. TFP method are more about saving you money by only adding what your pool actually needs.
    Algaecide does not kill algae. It's a terrible name for the product. It can help prevent algae if chlorine levels drop too low for a short period, but it's worthless for eliminating algae that has started growing already. The answer is always more chlorine. In the form of bleach (aka liquid shock), is the best in conjunction with proper testing and sticking with the SLAM process. Link in my signature.
    Mustard algae does exist, but most of the time, it's a scary term thrown about by pool stores to make you think it's a difficult problem that must be solved by lots of their products and lots of your money. The answer is still bleach and proper testing.
    Isolated Spa - 345 Gallons
    Jun 2016
    Freehold New Jersey
    14
    OK thanks I'll order a testing Kit. So the #32 bottler of Saltscapes that I can reture I guess I throw in the pool tonight & balance the water. I'll look at the slam process.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    jackgit. You stated you can brush it off, but also stated that the Vitamin C test lifted it. That's a little contradictory as explained in my first reply. I would hold off on the 43 OZ of Saltscapes Algae remover altogether. No matter what the stain is you do need to get that FC level up and possibly eliminate the CC (I say "possibly" because Dotty's computer test shows .60 CC - Eh? may or may not be accurate). It makes more sense, economically speaking to get that FC raised with bleach than the fancy bag of Burnout73 and no extra additives.
    You probably live w/in 5 miles of me. PM me if you want some help this weekend. I know that is a bizarre invite from some nameless guy on a public forum. But I've been at this for a long time and always willing to lend a hand.
    Feb 2014
    Central Minnesota
    5,080
    Good decision! Your water doesn't look bad, but not TFP great. The SLAM procedure will assure that your pool is algae-free. In the process, if the stains are organic based, such as from residual algae, those will fade/disappear as well. If the stains persist after you've cleared any possibility of algae, then they are likely metals and we can guide you through some approaches to remove those.
    Are you on city water or private well water? Kind of confused by your signature. Municipal water will nearly always have very low metals content so the likelihood of metals stains for a pool filled with city water is very low. That is unless pool chemicals containing metals have been used under direction of the pool store. Products containing metals are not recommended by TFP because they can cause staining and metals are not easy to eliminate from a pool.
    Once you have your test kit, post a full set of results and we'll help you out. While your waiting for it to arrive, you can keep the SWG running to try to keep the pool from getting any worse.
    Jun 2016
    Freehold New Jersey
    14
    I use city water from FHTWP they source the water from numerous wells.
    Test kit on order........... no more Pool store tests I turned off the SWG on Sunday to lower the FC & CL levels as per the stain out directions as a test removed the stains.
    This was prior to the pool store mustard discovery Thinking of throwing all this in the pool tonight anyway as nothing is returnable. Once the kit arrives I'll look injto the slam method.
    Mike M I'll take you up on your offer once I get this going & test kit delivered.
    Humm & I been using pool store tests since 2001....
    Jun 2016
    Freehold New Jersey
    14
    The kit arrived however prior to the kit arriving I added 1.5 ilb of Vit C and 43 OZ of Saltscapes Algae remover It did lighten up the stains however the pool is now partially cloudy.
    Because I lowered the CL level for the stain remover to work.
    I picked up 6 gallons at Walmart of f CL Bleach
    Last night I put 2 LBS of Shock & moved the SWG to Super chlorinate.
    Reading from the K00-6 this morning 11:00 AM
    FCL .8
    Combined 0
    PH 7.2
    ALK 100
    CYA 80
    So my shock level should be 31 How many gallon of bleach do I add?
    I'll do the OCLT test tonight
    Jun 2016
    Freehold New Jersey
    14
    Oclt test was a loss of .03
    i added 2 gallons to see how much cl would go up at 67 drops in the 25 mil I have 1.54 at the his rate I'll need
    To go to 31 shock level as per the charts with a cya of 80 I'll need 20 gallons ????? Is it his correct ? I just put a n 4 more and will measure in 1 hr Anyone around to answer?
    Feb 2014
    Central Minnesota
    5,080
    How did you arrive at 0.03 chlorine loss?
    Jun 2016
    Freehold New Jersey
    14
    the difference between morning & night tests I aded 6 gallona of Walmart bleach 2 hours later & went to test at the 10ML level I ran out of R-0871 because I put in 60 drops until clear
    The test look straight forward but .5x60 = 30 I guess I slammed correctly ? I just place an order for 16 OZ of R-0871 So I'll go to the pool store until received.
    I'll do a full test without CL tonight
    Feb 2014
    Central Minnesota
    5,080
    To perform the OCLT, you dose up to your shock level from the Chlorine/CYA chart, then you measure the FC 30 minutes later, when the sun is down.
    Then you must measure the next morning, before the sun hits the pool. Night FC minus the morning FC is your OCLT result.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Jun 2016
    Freehold New Jersey
    14
    Understand What about my last question? using a Taylor k-2006 kit When I ran the test at the 10ml level I had to put 60 drops of R-0871 to turn the sample clear.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by jackgit View Post
    yes. 60 drops in a 10ml sample uses a factor of .50. Which you did. What is the question? If you are asking if you are correctly calculating that as a 30ppm FC, then, yes.
    But from what I am gathering you are saying you didn't have enough drops to test again in the morning? Which defeats the purpose of the OCLT test, which I believe prompted JV's last reply.
    Jun 2016
    Freehold New Jersey
    14
    Understand at least the pool math was correct I got the level up to 30 with 6 gallons however its a loss now
    Ordered large R-0871 thru amazon will be here Wed.
    Thanks guys !! Next post Wed eve.
