Results 1 to 7 of 7
Thread: Cracks in NEW Pool plaster
    VFMA1991's Avatar
    Apr 2016
    Collegeville PA
    8
    New plaster
    Has anyone had crAcks in new plaster. The pool wAs filled within 4 hours of them finishing the player. Pool company came and looked at earlier in the week but they have not gotten back to me as to what and how to fix.
    VFMA1991's Avatar
    Apr 2016
    Collegeville PA
    8
    We have a new pool that was plaster three weeks ago today, We had cracks showing up in the plaster after the first week. I am have been waiting on the Plaster guys to get back to the Carlton Pools. What should their fix be? New plaster job? This crack is about 18
    May 2014
    Broken Arrow, OK
    8
    Re: Cracks in NEW Pool plaster
    My neighbors had a problem with their first plaster job. Their pool builder had a second guy come out to re-plaster it. I made sure to use the second plaster guy when I remodeled my pool. Most pool builders have a warranty on the plaster as long as you follow all their start up instructions.
    Built in 2000, remodeled in 2016 - 16x30 20k gal gunite pool with raised spillover spa, Pentair 011018 InteliFlo 3HP VS Pump, Pentair 188592 Quad 60sq ft D.E. Cartridge Pool Filter, Pentair inline chlorine feeder, Intermatic PE653RC controller, Raypak Heater 406,000 BTU BG ELE
    38,239
    Re: New plaster
    I think you need to press the builder for an equitable solution ... best solution might be a replaster job as I am not sure how widespread the cracks are.
    Jul 2015
    Central Valley CA
    1,107
    Re: New plaster
    I would start documenting with photos and emails just in case things go sideways with the builder. Hopefully there will be no need for a paper trail but better to start just in case. Also I see you have a couple posts around this issue I know it is stressful and you are trying to get information but please try to keep to one thread so information and suggestions don't get scattered.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    There is some info on cracking toward the middle of this article.
    Diagnosing Pool Plaster Problems
    VFMA1991's Avatar
    Apr 2016
    Collegeville PA
    8
    Thanks for your feed back. The Pool Company is going to replaster the pool. There were cracks in the shell that they were aware of that the did not address. The cracks are running all over the place. We are going to chip away and repair cracks in the fall and replaster in the spring is the game plan. I think their concern is that we are going to have more cracks. However, they are not saying it.
    850 sq ft. 40' x 22' 30k Gallon, 7 deep, Free form, Gray plaster, Sun deck, Heat Pump. 900 sq. of decking. Carlton Pool install 2016 and completed June 2016. Pool located outside Philadelphia, PA
