Thread: Aqua Logic T-cell 16
    Jun 2016
    Florence, N.J.
    3
    HI there, we've been having issues with error codes, High Salt Amps. we bought (2) replacement t-cell 15's for our pool. One was a "replacement", not the original brand, the other was a Hayward. I read a lot of reviews about the K1 relay and my husband re-soldered that. That seemed to fix the High Salt error. Now we are getting Low salt and the generator wont stay on, and that's with trying both new cells. The water tests have been right in zone between 3000-3300. Does anyone have any ideas about what the problem could be? It's been getting pricey after buying (2) new cells and we're hoping its something we can do without needing a new board.
    Thanks
    Djstaz
    Gunite pool / 22,000 gal./ solar panels / waterfall-slide / (2) 2HP pumps/ Aqua Logic AQL-PS 16 system
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Aqua Logic T-cell 16
    Welcome to TFP
    Most SWG read salt on the low side, try taking your salt level to 3500 and see and then 3700 if that does not work... Some SWG are just picky... I do believe the T15 like about 35/3600 salt level
    Jun 2016
    Florence, N.J.
    3
    Thanks for the reply, we were just afraid that it might burn out that k1 relay again. The system is only reading 2200 and we know the pool is between 3000 to 3300. At this rate anything is worth a try.
    Jul 2013
    Fletcher, OK
    3,353
    a salt reading of 2200 is way low, I don't know if the SWG will pick up a real salt reading of 3700, it would still only think it is 2700 and that is still low...
    Jun 2011
    Long Beach, CA
    2,790
    Please post all the diagnostic numbers.
    Do you have a pool store nearby that can check the cells? Most Leslie's have a cell check station.
    Jun 2016
    Florence, N.J.
    3
    Yes, Ping, I did contact a Leslie's pool store and they do test the cells. I would hate to think that (2) brand new cells would be bad, but I guess it is possible. I'll have to post numbers when I get home tonight. Thanks !
