Thread: Oh NO !!!! First time mistake
    May 2015
    Ten Mile, TN
    74
    Well, I installed a Hayward SWG last month and just had it to the point where the FC was dead on 3 ppm day in and day out. So I started measuring FC less frequently (every 3 days). I had a leak in the PVC pipe and temporarily took everything apart to fix the leak. Then after 3 days, I had a green pool bottom. I forgot to plug in the Hayward flow indicator and the SWG won't produce Cl without a flow reading.
    ARGH !!!!
    I just vacuumed and brushed and spiked it to 24 ppm FC with 60 CYA. And put DE in the sand filter. Looks a little better today, but still cloudy.
    ARGH
    24' Round 14000 gal AG - installed June 2, 2015
    Saltwater Hayward AquaRite w/TCell - 9
    Waterway 26" sand filter w/ 2HP 2 speed pump
    Taylor K-2006 FAS-DPD Test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: Oh NO !!!! First time mistake
    Just remember that any time your pool is not circulating and producing enough FC you can manually add liquid chlorine (aka "bleach") and mix it in to keep the water sanitized.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    with your test kit and knowing what to do its not a mistake, its a learning moment
    May 2015
    Ten Mile, TN
    74
    Quote Originally Posted by YippeeSkippy View Post
    Yep... That's what I did.....SLAMMED it with bleach. I didn't know it wasn't producing FC---that was the problem. When I was manually adding, I measured every day
