Results 1 to 15 of 15
Thread: Intellibrite Lights on Photocell - Crazy?
    Mar 2016
    New Orleans
    120
    So we have two 500w Intellibrite white lights in our pool, which literally just became operational. We don't have automation, so I had asked electrician about a timer for the lights, and he suggested a photocell, so I said great.
    Last night was the first time they came on, and those suckers are bright - really light up the pool!
    I think it's great to have them on the photocell, just have them on dusk to dawn, but I just wanted to make sure we're not crazy for doing so. I know the LEDs are rated for a crazy number of hours (my understanding is they say 50k, but 25k is more realistic, of course with the caveat that the rest of the fixture doesn't **** out), but I see people saying 15-20 years, and by my rough calculations, assuming it's on 11-12 hours a day on average (taking into account summer and winter), I only come up with like 6-7 years. Still doesn't sound too shabby, but I know those babies are pricey.
    Anyway, if anyone thinks we're completely insane for having them on a photocell, please do tell me. Don't worry, I have thick skin and can take the criticism 😉
    Thanks!
    New Orleans, 15,000 gallon IG free form Wet Edge Primera Stone Riviera Coast, Intelliflo Variable Speed Pump (011018), Clean and Clear Plus Cartridge Filter (160340), Rainbow R171096 Automatic Chlorine Feeder, TF-100 Test Kit, build March-June 2016, filled June 19
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intellibrite Lights on Photocell - Crazy?
    hmmm, I would say 3 to 5 years on 12 hours a night but if it looks kewl I have done stranger things
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    For me, as long as you still had a switch where you could manually turn them off and bypass the photocell control, that's great!
    Isolated Spa - 345 Gallons
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Many times pool lights draw bugs. LEDs aren't nearly as bad, but you may find a lot of bugs on the surface of the water the next day.
    Feb 2014
    Central Minnesota
    5,080
    That's a great point... the other night we left our light on for an hour or so after everyone had gotten out of the pool. When I went to put the solar cover on and turn off the light, there were about 20 june bugs floating on the surface near the light.
    Jun 2015
    Orange County, CA
    145
    Not crazy, but 500 watts is a lot and will decrease the life of the bulb, not to mention the energy used. I would put the photocell on a timer like what low voltage lights use so you can set how long you want lights on or 4 hours after dusk, 6 hours after dusk or all night if you want but at least you have options.
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    Mar 2016
    New Orleans
    120
    Thanks all for the responses. It did seem to attract some bugs last night, so I feel a little bad for the ones that gave up their lives, but it wasn't too bad.
    We do have just the breaker switch, at the pool breaker box, which is with the equipment, right beside the pool, so easy to get to. But I certainly don't want to be going and turning them off every night and back on next day, obviously that would defeat whole purpose. I guess we could leave them off like in the non-swimming season, but being in NOLA, we don't close the pool or anything, so might still want them on (though I guess it looks kind of funny if the solar cover is on, and in any case, wouldn't be that much of the year. And we could turn them off when we're not around, but we do have a rental unit, and guests will be using pool, so probably wouldn't want to do that.
    Love the idea of having the photocell on a timer, that would be perfect. Just asked electrician about that and he said, "I believe they have a timer based photocell...we can't use the timer in the panel because it is for 220." So not entirely clear on what that means, but he said he would look into an option for putting it on a timer. I think that would make the most sense, would be nice to have them on for a certain number of hours, but really no need for them to be on all night.
    Thanks again!
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Would putting it on something like this work? Like the switches at hotels for their hot tubs or tennis court lights?
    Intermatic Timer, Spring Wound FF6H | Zoro.com
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Mar 2016
    New Orleans
    120
    Hmm, don't know. But that looks like something you'd have to set each time? Would kind of defeat the purpose...
    Mar 2015
    380
    Yeah, have to twist it for how long you expect them on. Tenants could turn them one when they needed it as well. So, yeah, if on 100% while dark that wouldn't work
    Scott
    Mar 2016
    New Orleans
    120
    Aha. Well that might be a possibility, I appreciate the suggestion. But I think that's less than ideal, I'd really like a solution that doesn't require setting every time, that's what I'm going for.
    Hopefully electrician will come up with something, he's pretty savvy.
    Mar 2015
    380
    If not worried about bulb life your plan still sounds fine and neat having it light up. No different than landscape lights many leave on. Shouldn't be hard for the electrician though if just looking for always on but some kind of timer in series with the photo cell to just restrict the total time some to prevent daytime use during storms or to turn off at some point in the middle of the night when you know you would always be in bed by then anyway.
    Scott
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,215
    Have him come out of the breaker box at the equipment pad and install a weather rated box. Lowes sells a timer switch that you can program up to 10 different on/off events. I use it for a post lamp by the driveway and high hats on the front porch. The only time I mess with them is when there is a time change for daylight savings.
    Like this. Shop Utilitech 15-Amp Digital Residential Hardwired Countdown Lighting Timer at Lowes.com
    Support the site
    Mar 2016
    New Orleans
    120
    That's exactly what I'm going for, NeedMoreSun. Hmm, that's a good suggestion, Tim. You mean a water rated outlet?? We actually have one right there, so maybe that will be easiest. Will discuss that with him? That's exactly what I want, just to change it for daylight savings, and maybe when days get longer and shorter. Thanks!
    The LED board inside the color changing IntelliBrite fixtures is field replaceable, I'd presume the white would be the same? The bigger issue will be whether the LED board is still available in 15 years if it were to fail. As far as adding a timer, if you have the electrician add the timer contacts after the photocell, you could set the timer to turn on at noon and off after you go to bed. The photocell would keep the light off when the timer turned on at noon and would turn the light on when it got dark. The problem with a timer only solution, which is what I currently have, is that I have to adjust the dusk on time several times a year to accommodate the change in sunset time.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
