Thread: One week into a SLAM
    Jun 2016
    Suitland, MD
    18
    I started a SLAM a week ago after finding this website. The green swamp cleared up in about 3 days and for the last 3 or 4 days I have pretty nice looking water, however it is not crystal clear yet (it is very, very close). Tonight I am going to do the OCLT and see what that looks like. We had a ton of rainfall last night and after it ended I tested the water using the K-2006 kit. The kit is new to me as well as the website so I hope I am getting accurate results.
    FC 9.5 (added bleach last night and this morning FC is 15)
    CC .5
    PH 7.5
    TA 110
    CH 160
    CYA 30
    I guess my question is how do I know when the water is clear enough? And do I need to make any other adjustments to get the water to crystal clear?
    Sue from Maryland
    13, 000 gal. 24 foot round pool, vinyl, in-ground (no main drain), Hayward sand filter, 3/4 hp pump, Aquabot s2-50
    Mar 2015
    South Texas
    411
    Re: One week into a SLAM
    It sounds like you are doing everything correctly. Things that can speed up a SLAM are being vigilant about maintaining that FC at 15, brushing the pool often being sure to pay special attention to crevices like lights, return, ladders, etc.
    Also, running your pump and filter 24/7 and cleaning it often also. Dead algae really clogs a filter fast.
    Best of luck
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Jun 2014
    14,970
    If you didn't already know, you can use the 10 ml testing method with your K-2006 to save on reagents.
    10ml sample with ONE heaping scoop of powder. Count drops until clear and multiply 0.5 (divide by 2).
    Once you pass the SLAM criteria, you can also consider adding a little amount of DE to your sand filter to enhance it's filtration capability as noted on the TFP Pool School - Add DE to a Sand Filter page.
    Jun 2016
    Suitland, MD
    18
    Quote Originally Posted by Texas Splash View Post
    I figured out I could test with the 10 ml after quite a few of the 24 ml testings. Ran out of reagent on Sunday and ordered new. I am still using two scoops but will change to one heaping, thanks.
    Also, I have already decided to add some DE to the filter and have it in my head that this will be the best year this pool has seen in many, many years.
    I have been using a skimmer sock and this morning was the first morning that it wasn't tinted green. It was a little brown but I think that was because of everything that washed in with the huge rain storm last night.
    Sue from Maryland
