Thread: Hayward Filter Gurgling
    I ran my Hayward sand filter in the closed position overnight and it blew the main hose to the pump. After reattaching the hose and positioning the multiport valve to "filter" I am hearing a gurgling noise under the multiport valve. Have I messed up?
    13x21 vinyl aboveground, appx 10k gallons
    Hayward Power-Flo LX 1.5hp pump on 115 volts
    Hayward sand filter
    Blue Solar Cover
    Hayward Aqua Critter
    30,431
    Re: Hayward Filter Gurgling
    Probably air in the system....no harm. Curious why you closed the system and tried to run the pump?
    I don't have shutoff valves so to clean the basket, I put the filter in the closed position then remove the basket cover to take the basket out to clean it.
    Hayward sand filter
    Blue Solar Cover
    Quote Originally Posted by burt4750 View Post
    ?? The pump is before the filter, I'm not sure closing the valve on the filter will do anything, once you pop the cover to the leaf basket the water pressure from the inlet is going to blow water everywhere.
    Edit: maybe your setup is different than mine though -- but on mine it goes skimmer, leaf basket, pump, filter, return.
    Under Construction - Coleman 18' x 48" Above Ground Pool (6200 gal)
    Intex Krystal Clear Sand Filter Pump, 14", 2800 GPH
    Sioux City, IA
