Thread: CYA Reagent "Compatability"
    Nagorg's Avatar
    Oct 2015
    Dallas, TX
    15
    Hello,
    I have the Pentair-Rainbow reagent kit with the sliding test tube. Is the Taylor R-0013 reagent compatible with the Pentair sliding test tube?
    Pentair uses different part numbers than Taylor and it isn't clear (to me at least) if there is any different in the reagents. I can buy Pentair reagent but seems like Taylor R-0013 may be cheaper.
    Thanks TFP!
    My Pool: In-ground, ~15,000 Gallons, Fresh Water, Plaster/Gunnite or what ever..
    Shape - Roughly like an oblong figure 8 / somewhat oval
    Depth - ~4.5-5 ft
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: CYA Reagent "Compatability"
    I would stick with one supplier across the entire kit. It probably works but why mix and match and have doubt? The majority of this forum is using Taylor products where the vials, test tubes, comparators, and reagents are all meant to work together. You wouldn't use an HTH comparator from Walmart using Taylor reagents, would you? Same applies here.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Nagorg's Avatar
    Oct 2015
    Dallas, TX
    15
    Quote Originally Posted by mikemass View Post
    Well, that's why I'm asking the question; to remove doubt. Just looking for anyone that might be in the know on this topic. Given the nature of the test it seems reasonable to think that the its the same chemical being used to produce turbidity in the water that will obfuscate the black dot at depth. So again, just looking for anyone that can speak authoritatively on the subject. Easy enough to buy the same stuff but if I could save a buck or two.... All in!
    Depth - ~4.5-5 ft
    Jun 2015
    Freehold, NJ
    20
    I havent seen each tube side by side. But i have used the Pentair tube with both the Taylor and Pentair reagent and received the same results.
    Nagorg's Avatar
    Oct 2015
    Dallas, TX
    15
    Thanks for the feedback 1stand2rd.
    Depth - ~4.5-5 ft
