Thread: Jbirdtroutman
    Jbirdtroutman
    New to forum. I am from KY. Building our own I vinyl liner steel wall pool. 18x36 sand filter, salt water system. Our excavator dug the hopper too big and the slopes are too steep. What can we do to fix this problem? Any help is appreciated. Thanks!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Jbirdtroutman
    Welcome to TFP
    I have seen crushed rock and sand is used to "sculpt" the bottom before vermiculite is put in. exactly how they do it I am unsure, who is doing your vermiculite install, maybe they will be able to fix it
    Re: Jbirdtroutman
    Thank you. I will check with a local Pool company. We originally planned to finish bottom ourselves but this may be more than we can handle
