Results 1 to 18 of 18
Thread: Quick Stenner install question
    Jun 2015
    Dallas, TX
    148
    I'm putting my Stenner in and was hoping for help with a fast question on where to tap in for the injection quill. In the picture below, the pipe with the red line is the main return line going from the heater to a Jandy valve (the valve splits between the spa jet returns and the pool returns - the right side that goes to the pool returns also has one "feature"return that comes up through the floor of the spa, so the spa still gets some return water when the Jandy is set to the right side).
    Am I correct that I should tap in for the injection quill somewhere along the red line? Thanks for any help or input.
    9,000 gallon IG pool with spa, Pentair FNS Plus 48 DE filter, 2HP Whisperflo pump, 0.75HP Letro booster pump, Polaris 280 cleaner, EasyTouch controller (originally a Compool LX100 that was upgraded via Pentair's upgrade kit), TF-100 kit
    Jul 2015
    Central Valley CA
    1,108
    Re: Quick Stenner install question
    Most are done in a fitting because the wall is a bit thicker there. So with that in mind I would tap into the the elbow at the top of the red line near the blue tank or the one near the rear of the booster pump or the one from the heater leading down to the booster pump. Nothing wrong with somewhere on the red line either just leave enough pipe before the jandy for a splice should you ever have to do a repair or replumb say at least 5 inches before the jandy.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2016
    Rockville MD
    43
    With a little more effort, you can install a T connector with a threaded outlet that the injector threads into. To me, it seems a little more sturdy that way.
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    May 2015
    katy, tx
    31
    I like the threaded outlet. Should you ever need to take it out for some reason you could just put a threaded plug in it. I put mine in the threaded drain plug of my chlorinator for this reason. Learned my lesson replumbing after moving from liquidator to stenner when I drilled straight into the pipe. Wasn't difficult to fix, just one more thing to do and couple more things to buy.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by downtfish View Post
    Thanks for the thoughts. Although if I just drill and tap straight into the pipe, couldn't I still just put a plug or short bolt into the tapped hole if I want to remove the injection quill?
    Aug 2009
    SW Wisconsin
    518
    you could..but a threaded outlet is "structurally" more sturdy, than a hole drilled through the wall of a piece of pvc Pipe. I have the "T" fitting as shown above on mine as well, and it works great.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by flyweed View Post
    Hmm...ok, dumb question - how did you get the tee joint inserted? I'm thinking that once I cut out a part of the straight section, the rest of the pipe might be too rigid to slide in the tee on both sides. Did you use a union? Or is there another way?
    I know this is a simple question but I've never inserted a tee before and know it can be tricky in some setups. Thanks for any pointers.
    Mar 2015
    Sugar Land , TX
    424
    I would drill and tap at the 90 degree elbow that is close to your blue tank in picture. That way you have a thicker wall to tap into and less chance anyone could bump into the injector and break it off.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    May 2016
    Woodland, Ca
    234
    I'll add a plus one for installing the T fitting. Looks like you have plenty of wiggle room on the line with the red line. Worst case you could disconnect it from the heater.
    Is that an inline chlorinator? Does it have a fitting you could use?
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Quote Originally Posted by lvrpl View Post
    It can be tricky....sometimes you can't tell how much wiggle room you actually have until the cut it made. That happend to me...thought there would be enough room but turned out much less than I anticipated.
    What I had to do is get a telescoping coupler/union from Home Depot. Requires that you cut out about a 6" section of the pvc, glue one end of this type extender/union to one butt end of the cut out pvc section. Then glue your tee in the other butt end of the opened pvc section. Finally, coat other end of tee and the extender and extend the telescoping union into the tee. The amount you cut out of the existing PVC section has to be carefully measured so that the telescoping union gets fully extended when joined up with the Tee.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by CaptainCannonball View Post
    It is an inline chlorinator (Frog brand)...I assume you're thinking I should just use the drain fitting on that? Any idea if those threads would match the injection quill on the Frog brand? And would that be a superior way to plumb in the injection quill (versus drilling and tapping the pipe)?
    One other question on the Stenner - the tube fittings come from the factory in an orientation going off the left side of the pump. Is it possible to rotate the head so that those tubes come directly off the center or right side?
    Thanks again for all the help.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    It is a bad idea to inject liquid chlorine into an existing solid chlorine feeder. Mixing types of chlorine can be hazardous, even explosive. While you may know not to have solid chlorine in the feeder when injecting liquid through it family members or future owners of the house may not.
    Support the site
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by tim5055 View Post
    Ah, ok, great advice, thanks. I'll put the injector directly into the line. I'm starting to feel a little hopeful that I might have enough play in the pipe to put a t-fitting in after wiggling it around a bit. Or I may just drill and tap into the pipe directly with the knowledge that I can always put the tee in that same spot later if desired.
    Any insight into whether I can turn the orientation of the pump head to have the tube outlets in the center or on the right side?
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Using your chlorinator as the insertion point will pose no risk if you simply glue the chlorinator cap on so as to permanently keep anyone from being able to place chlorine pucks into it. Loads easier than going the tap or Tee method to accomplish the insertion point, though I am not at all trying to discourage you from doing either of these to configure the insertion point.
    May 2016
    Woodland, Ca
    234
    There is nothing wrong with drilling and tapping into your pvc, but also there isn't really any advantage to do so over installing a slip T with a 1/2"npt if you have the space. Most any hardware store will have it for $2-3 plus the price of primer and glue. The cost of just a tap would be more in parts and if you are the kind of guy who has a tap and die set then you probably have primer and glue anyway meaning it's just your time. I'm not a mechanical genius, but cutting and gluing pvc versus drilling and tapping would be about a wash time wise. With the T fitting, in my opinion, you have a more structurally sound connection, less obstruction and it doesn't look hackish.
    To to be clear, I was not suggesting you use trichlor pucks and feed the liquid chlorine into your feeder at the same time, it was just a thought to use an existing threaded port from an abandoned chlorination device. I had the idea to use my drain on my pump for the injection point, but decided on this: image.jpg
    Jun 2015
    Dallas, TX
    148
    Makes sense. i guess I'm just wondering if I'll have enough wiggle room in the pipe after cutting it to get the tee fitting on...I'd hate to cut it out and then not be able to slide the tee in. I agree that the tee is a better connection but the tapped hole will avoid that risk. But I'm thinking I'll probably have enough play to get the tee in, at least I hope...
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    When I installed my coupling I got my extra "slack" from disconnecting the connection to the heater. If you do it be sure to not lose the black o ring or you will develop a leak. Took me about 10 minutes to patch it in. I now have a SWG but I still plan to use the Stenner during cooler months when I have to haul less bleach to the tank. When not in use I just insert a threaded plug.
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    Mar 2015
    Sugar Land , TX
    424
    Well alot of opinions on how to install the injector. I think all the ideas proposed will work it is just what you feel comfortable with. Good luck with your install and enjoy your new freedom with the Stenner!
