Results 1 to 7 of 7
Thread: Hayward CL220
    Jun 2014
    LI, NY
    13
    Hayward CL220
    My chlorine feeder started spewing water today. What exactly do I need to do to temporarily disconnect it until we can change it?
    New Pool Owner - Please help!!
    23k? gallon 16x32 Vinyl IG, Hayward Micro-Clear DE 4800 filter
    Hayward CL220 Chlorine Feeder, Polaris P955 cleaner
    TF-100 test kit, Full sun until 5pm
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Hayward CL220
    Is there a shut off valve for the chlorinator? Can you post a picture of the problem?
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    LI, NY
    13
    Re: Hayward CL220
    No shut off valve that I know of or see.
    Looks like we will be converting to SWG sooner rather than later but we are going away this weekend so I need to figure something out.
    Jul 2009
    Houston, Texas
    9,429
    Re: Hayward CL220
    I can't tell looking at the picture. Where is the leak on the chlorinator?
    Love TFP? Become a
    TFP Supporter!
    Re: Hayward CL220
    Probably just a bad lid oring cl200k. The lid comes apart. Pop off the top cover plate with a flat screwdriver to access the lid nut. Remove the nut to disassemble the lid and access the oring.
    If you need a quick solution, you can remove the chlorinator and run one side of the tubing from one pipe to the other. The tubing nuts unscrew and the tubing pulls out.
    Support the site
    Jun 2014
    LI, NY
    13
    Re: Hayward CL220
    Leaks from the lid. O ring is good. It was just replaced.
    Hubsband says they're are spider cracks in the lid. I'll try to take a pic when back home.
    If I disconnect one of the lines, do I need to plug where it connects to the PVC?
    Re: Hayward CL220
    Just run the tubing from one pipe to the other.
    Support the site
