Thread: TA for a Salt Water Pool
    Jun 2011
    Shelbyville, Indiana
    11
    Just fired up my new Circupool RJ-45 SWG and have a question concerning my target TA numbers.
    I am currently shooting for a TA number between 60 to 80 points as per your recommendations.
    Circupool ideal water chemistry numbers for TA are 100 to 200 points.
    Should I keep shooting for the 60 to 80 point ( I am currently at 120 points), or use Circupool's suggested numbers.
    What are the pros and cons??
    Your thoughts??
    Monty1
    Vinyl Liner-24K-2 skimmers-bottom drain
    Sta-Rite sand filter
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,764
    Re: TA for a Salt Water Pool
    TA acts as a pH buffer. A lower TA makes the pH more stable and limits/slows its rise. If you follow the 100-200 ppm recommendation, you will go through a lot of acid and be adding it very frequently.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    I'd use their recommendations ONLY IF they're willing to send you FREE muriatic acid! That SWG is automatically gonna tend to drive up your PH as is.
    Jun 2011
    11
    Thanks, guys.
    I will continue to lower the TA numbers until I reach your recommended goals.
    Monty1
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
