Thread: Helping neighbor become a Trouble Free Pool owner...
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    And after draining the pool by half I got the pool form 120 CYA to 60 and CH from 440 to 360...then I had pH of 7.6 after shocking for two days. Then rechecked FC was 7...target 5 to 9 ppm. And oH was still 7.6. TA was 110.
    A week later the the pH is 8.2 or higher, and TA went to 220 ppm.
    First why...i need to understand that, and then pH down to 7 to 7.2 then aerate back up to normal pH?
    I really want to know what caused this. As I wonder is it from bringing shock level up to 32ppm and holding it there? If that's the case will it go down over time.
    30 x 12 in ground fiberglass pool.
    Numbers tonight were
    FC 10 ppm,
    CC 0
    PH 8.2 or higher
    TA 220
    CYA 60
    Any thoughts
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Helping neighbor become a Trouble Free Pool owner...
    What test kit are you suing to gt these results? What chemicals have been added to the water? How does the water look?
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by YippeeSkippy View Post
    Brand new tf100...water is crystal clear. Better than it's ever been. They'd been using tri Chloe pucks for years and I drained down 1/2 the water last the previous weekend, refilled, balanced, tested then shocked...things were fine a week ago. She's added chlorine and last night FC was 10 ppm.
