Thread: jets returns dirty water after vacuum
    May 2016
    Schaghticoke, NY
    2
    Hello.. i have a Hayward Vari-Flo XL valve model SP714 sand filter. Its been running 24/7 for 7days after a super shock due to extensive algae growth. Pool not clearing. Vacuumed for a few minutes, removed vacuum attachment and the green algae water was pushed back in pool thru the jet. I did clean filter basket and found a bunch of sand which i cleaned out in order to put back in. Barely any suction in vacuum, filter has not "told" me it needs to be backwashed as of yet and its been 7 days. I do believe spider gasket is bad due to water dripping out of waste spout. Not sure if this has anything to do with the problems above. Also there is sand in the looking glass on filter. Looking for suggestions on what the problem might be. Thank you in advance 😀
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: jets returns dirty water after vacuum
    Welcome to TFP!
    With algae in the pool you should expect to backwash frequently. Nothing clogs a filter faster than algae. Most times they need to be cleaned every 1 to 2 days with algae. We recommend backwashing a filter when the pressure rises 20-25% over clean pressure.
    Here are a couple of handy articles about filter maintenance
    Pool School - Maintenance and Cleaning of Pool Filters
    Deep Cleaning a Sand Filter
    May 2016
    Schaghticoke, NY
    2
    Thank you for responding. The filter normally runs at 10psi and it has not gone up in the 7 days its been running, i have backwashed but the water is clear and the pressure seems to be a bit weak to where the water comes out like a fan.
