Thread: Feeling Successfull
    Jun 2016
    Central Oklahoma
    59
    Feeling Successfull
    I take my pool water in and have it ready by a machine today.. Cost $5.00 if you don't buy chemicals, feel it is worth it since I don't have a test kit yet..
    FC .39. Low so I put in recommended amount of bleach.
    pH 7 added borax
    TA 109
    CH 346
    CyA 53
    Original filled pool from city water where my TA was extremely high. Took 4 gallons of muriatic acid to bring it down so that is why pH is out of wack. Hopefully SWG can keep clorine levels stable now.
    May/2018 AGP Coleman 24x52 vinyl, 13.6k gallons, Harris H1572228 Vortex 16 inch Above Ground Sand Filter System with 3/4 HP Pump, PoolBlaster Max, TF-100
    Run pump 24/7
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Feeling Successfull
    Welcome to TFP!
    You should only feel successful if their testing is correct, and I doubt it is.
    The borax you added also added to TA at least a little. The idea for reducing TA is to drop both pH & TA with acid and raise pH with aeration. When you chemically raise pH it also affects TA.
    You really need your own accurate test kit.
    Support the site
