Thread: Have algae and CYA levels in pool are at 90-100 and can't drain
    Jun 2016
    phoenix, AZ
    15
    I live in Arizona and the temperatures are at like 100-110 on average right now and my CYA levels are through the roof. I have green and black algae in the pool and don't really know what to do since my cya levels are so high and it would ruin my pool to drain in this heat.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Have algae and CYA levels in pool are at 90-100 and can't drain
    You do not have to drain 100% all at once. You can do a series of drain and refill cycles to lower the CYA draining only a 1/3 of the pool at a time.
    Love TFP? Become a
    TFP Supporter!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    If you are able to, drain down in the early evening for a few hours (no sun on your pool) then fill it
    up over night.
    I had to do this 3 times to get cya of 300+ down to 80. (drained down until I could see the top of the light ring which was just over 3 feet of water)
    Just so happened that if I drained for 4 hours, the tap water from the hose on full would fill it from 9pm
    and be full to the skimline by 7am, but that water pressure was pretty low.
    This was on a 20,000 gallon pool
    if any of the above helps..
    Dolphin E10 Cleaning Robot.
    Jun 2016
    Martinez, CA
    207
    You can also have it RO filtered by a outside company. This runs ~$600 here in norcal.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    But I'm not sure if they'll do an algae filled pool, Rossterman?
    Jun 2016
    Martinez, CA
    207
    I'd call them and ask. Why not just slam it using the cya/chlorine chart to kill it off, vacuum it to waste, and then get if filtered? Leaving acitve alge in the pool while cleaning the water seems counterproductive. You probably will want to backwash or clean the filters while they do their work anyway.
