Thread: Replace light fixture or bulb and gasket?
    Jun 2016
    Lancaster, PA
    1
    After reopening our pool this year, our pool light was no longer working. It worked OK when the pool was closed, or at least shortly before that.
    I finally got around to taking the light out and looking at it... the pictures are attached.
    I confirmed with a multimeter that the bulb is dead, but electricity is being supplied to the fixture. But the bulb and fixture both look a little bit corroded to me. Should I replace the fixture, or just replace the gasket and bulb?
    Thanks for any help,
    Ed
    Apr 2013
    Sacramento, CA
    2,769
    Re: Replace light fixture or bulb and gasket?
    The bulb needs replacing. The fixture appears ok. It appears your gasket leaked. Was there water inside?
    I would get a new bulb and gasket and carefully replace and reinstall.
