Thread: First Test w/TF-100
    First Test w/TF-100
    Hi all,
    Just received my TF-100 yesterday. After holding the wife at bay for a few days from going to the pool store, I think she's on board with managing the pool the TFP way.
    My first results are:
    FC 34
    CC 0.5
    TC 34.5
    CYA 80
    TA 160
    PH 7.8
    I confess to adding a decent amount of bleach while waiting for the kit to arrive. The pool is clear and I've turned the SWG off until the FC drops.
    Is there anything else I should do at this point?
    -Chris
    24'x52" Round Above Ground Pool - 1.5HP Hayward Power Flo LX Pump - Dream Line High Rate Sand Filter - Intex SWG
    triptyx's Avatar
    Apr 2016
    1,438
    Re: First Test w/TF-100
    For now, I'd personally wait until the FC came down to target, which is 6 for your CYA level and an SWG (Pool School - Chlorine / CYA Chart). I'm also assuming your pool is nice and sparkly and doesn't have anything growing in it.
    Have you tested salt levels to make sure they're good as well?
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jul 2015
    Central Valley CA
    1,109
    Welcome to the forum
    If you added that much bleach because you started with algae and were attempting to do a SLAM then depending on how the water looks you can move on to an OCLT tonight and see if you pass then let the FC level drop. Don't bother adjusting the pH until the FC level is below 10 the readings you will get above 10 ppm FC are erroneous.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Quote Originally Posted by triptyx View Post
    Salt levels are good.
    Tested the FC and CC again last night. FC only dropped to 33 which surprised me. CC was still 0.5.
    Pool is clear. I'll just sit tight and wait for the FC to drop unless there's something else I should be doing in the interim.
