Thread: Preparing for Ascorbic Acid Treatment - pH rise with Polyquat 60
    Jun 2015
    Washington/DC
    25
    In preparing for an AA treatment to remove metal staining, I lowered my pH from 7.6 to 7.2 with Muriatic Acid on Sunday evening. Tested again last night and pH was still at 7.2. As a note my CYA was between 20-30 and my FC was at 5. Following the test I added 48 oz of Polyquat 60 anticipating it would further reduce by FC by morning and I could start the AA treatment. This morning, my FC was at 4 (tested using my DPD drops and not my TF-100 Taylor chemicals) and my pH had jumped back up to 7.5. I can lower the pH again by adding more MA, but before doing that and proceeding with the AA treatment wanted to get input if there is something else going on I should be paying attention to before proceeding with adding the AA. How long should I wait between adding the MA and starting the AA treatment, the standard hour or two the MA normally takes to mix in and reduce my pH or should I wait longer?
    28,000 gallon in-ground freeform plaster pool with attached built-in spa
    Sta-Rite DuraGlass single speed 1HP pump - P2RA5E (Age Unknown)
    Pentair Tagelus 60d ClearPro sand filter (May 2016)
    Polaris PB4-60 booster pump (June 2014) for Polaris 280 (Age Unknown)
    Raypak propane heater (Age Unknown)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Preparing for Ascorbic Acid Treatment - pH rise with Polyquat 60
    I would lower to the recommended pH again with muriatic acid. If you let it circulate for an hour, that's plenty. Could even do less if you brush the pool.
    Isolated Spa - 345 Gallons
    Jun 2015
    Washington/DC
    25
    That makes sense but why the pH rise overnight in the first place I guess is my first question? Does Polyquat 60 cause pH to rise? I've had near constant pH between 7.4 and 7.6 since opening a month ago so it just seemed odd. TA has been between 80 and 90 as well (80 seems to be the normal sweet spot).
    Jun 2015
    Washington/DC
    25
    So bizarre. Just retested before adding MA and my pH was down to 7.4. Wasn't sure so retested and confirmed. Must have gotten a fat or extra drop this morning. Lesson learned to always retest if an unexpected result is achieved to eliminate human error. Confirmed no more FC so I guess it's time to start after the MA dose I just put in mixes. Just hoping the rain stays away the rest of the evening so I can get it done. If not then it will be an early morning for me.
