Results 1 to 16 of 16
Thread: Poll: Flagstone vs Pavers
    Feb 2016
    Atlanta, GA
    145
    Question Poll: Flagstone vs Pavers
    So I'm in the process of building my own pool, we are aiming for a spring 2017 open.
    In the past I decided on pavers, however I would like to get more opinions to help decide.
    I really like the look of flagstone and it is more affordable than I thought.
    It seems pavers are more functional.
    Cost and installation labor aside, what are your opinions on the two?
    Flagstone:
    Looks better/more natural/more 'high end' in my opinion
    Won't show stains easily
    Can crack
    Hard to repair / replace stones
    Pavers:
    Easier to maintain? (no annual sealing?)
    Easier to repair / re-level
    Won't crack (generally)
    Not permanent (can get under and repair pool pipes in the future)
    What would you go with?
    Below is three inspiration pictures i found on google. One has the grey/blue flagstone, brown flagstone, and pavers i like.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: Poll: Flagstone vs Pavers
    Here's a pic of a pool with pavers -- note the weeds growing in the cracks. I wouldn't be comfortable with roundup around my pool, and the weeds would drive me nuts, ymmv...
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Mar 2016
    McKinney, TX
    156
    I've always heard flagstone gets very hot so I wouldn't want it for a deck here in Texas. We have travertine pavers, but haven't had them long enough to find out if weeds will be a problem.
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
    Aug 2014
    NJ
    435
    Polymeric sand in between the paver joints helps prevent weeds from growing. The polymeric sand when wet hardens and prevents the weeds. It lasts for a number of years and then you may need to reapply it.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Mar 2016
    McKinney, TX
    156
    Yes we have polymeric sand between our pavers. And the gaps between pavers are very tiny so hoping it won't be a problem!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    We've had our polymeric basketball court for 6 years and some weeds are starting to shown up. Will need to reapply soon.
    Out PB wasn't a big fan of pavers next to a pool because repeated water on the polymeric tends to cause it to lose its binding capacity more quickly than it would otherwise...and therefore wash out quicker. Not sure the truth of it but he was quite knowledgeable. I could see the logic in it. But I also don't see it as a really big deal in reality because no one seems to complain about it.
    My feet are hot just thinking about a flagstone deck in GA.
    The first pic looks like PA bluestone and the second OK flagstone. The former is hot I guarantee you. We have that as our coping.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2016
    Atlanta, GA
    145
    Thanks for the feedback!
    I honestly have not thought about how hot the deck will get.
    That may be the main reason to go with pavers even though I love the flagstone look.
    I am not too concerned with weeds, what multiple layers of fabric and sand won't stop - my weed burner/flamethrower will take care of without having to spray chemicals.
    bmoreswim:
    Your flagstone deck looks great! Trouble Free Pool
    Nice mix of the grey/brown stones.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Thanks. They are fake. Painted concrete that is fading. But I'm easy going about it.
    Aug 2014
    NJ
    435
    Quote Originally Posted by sham View Post
    I'm not sure about this but in my very limited experience having too small a gap prevents the polymeric sand from working well.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Typically pavers have spacers built into the side of them so there is a consistent roughly 1/16" gap around them. The polymeric sand is not only spread with a broom but must be worked into place with a vibrating compactor run over the surface then more sand added. And many once more over with the equipment then topped off with a brushed in layer for a really thorough job of getting the joints full top to bottom.
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Hi. I vote pavers but it's a tough call. I like the way the FS is laid out in those pics. I have pavers (tech bloc Blu 60) around 25% of the pool (rest is grass) and they get HOT. Hot enough that you would burn your foot so if heat is the deciding factor don't worry b/c either one will be boiling in direct sun. If you go the paver route be mindful of the type. I have a friend who has small pavers (almost octagon type shape) and the edges are very rough. Every step you hit an edge and it hurts after a while. With larger pavers you'll minimize this and if the edges are more rounded it won't be an issue. As for access to underneath, the pavers still need to be re-installed so there is a lot of labor too. I like the way both look but my preference is for pavers just for the uniform look. Weeds will grow from seeds that blow into the cracks, not from underneath. If you blow the decking regularly it can help keep the seeds off. But have someone re-sand every 5 years and you won't need to worry about it. Just my .02
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have stamped concrete around our pool which is sealed with Shark Grip. We have pavers on our outdoor kitchen and fire pit area which yes gets weeds and moss even after having it power washed and polymeric sand reapplied last year. I actually bought a weed wacker just for the weeds that come up between the pavers. Drives me nuts!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2014
    Houston tx
    2,525
    We use RoundUp on ours in the driveway. Works well.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Aug 2017
    Marana,AZ
    2
    We had all of our flagstone removed this spring. Put every kind/brand of sealer they sell on it and it never stopped spalling, flaking, etc. I like the looks of the pavers but it's going to partly depend on where you are. In AZ those will get so hot you can't walk on them barefooted. We went with a textured concrete and the best cool coat finish on the market, very happy with it now.
    Jun 2016
    Virginia
    118
    We have pavers laid on concrete slab so no possibility of weeds. We also have bluestone coping. The bluestone is hotter than a pistol in temps 80 or above, while the pavers stay relatively cool even with temps in the 90s. But, our pavers are light grey. A nearby hotel has darker pavers and they are too hot in the summer to walk on barefoot.
    Regarding costs, we found the bluestone material is relatively reasonable but installation costs were very high, making the total cost almost double the total cost of installing pavers, at least in our area.
    IG Gunite 20x40 pool with Pebbletec finish (Tahoe blue with luminous glass in mixed jade); Pentair DE Filter and Pump; Intellibrite LED lights; RayPac 8350 Heat and Cool Heat Pump; NPT Arctic Ice glass tile; Coverstar autocover; Cambridge Renaissance Pavers in Onyx Lite; bluestone coping.
    Jun 2016
    NE/Pa
    1,160
    Weeds will still grow in joints of pavers even on a concrete pour. That doesn't stop a weed from rooting. The sand in he joints is thier bed material. They will also eventually grow in the poly sand. It you should prob be replacing the sand by that point though.
    Weeds grow in anything. They grow in cracks of driveways cause dirt gathers in the joints and then a weed seeds to grow.
    35x23/20 free form gunite 3.5-6 feet water. approx. 20,000 gallons. no spa or water features. 2 skim, 2 ret, floor ret, floor return. 2 inch solid. suction cleaning line. 1.5 inch solid. super blue diamond brite. NPT Gemstone Blue 2x2 with custom waterjet cut Disney Mickey markers. all pentair equipment. master temp 300,000 BTU. de 60. inteliflo 3.0 VS. swg ic40. 3 globrite LED lights. easy touch 4 with screen logic. tf-100/ salt kit
