Thread: Metal stains from Brite Stix I think
    Feb 2015
    Grand Rapids MI
    53
    Hello everyone,
    I had an issue last summer with metal staining that I was not sure of what the source was. It was either algaecide the pool company dumped in or Poolife Brite Stix I used for a bit. Both of these contained copper. This year there was no algaecide put into the pool and I forgot that the Brite Stix might have been the culprit. I used a few over the past week or so and now the stains are coming back lightly. I'm guessing the source is the Brite Stix. They contain 1.5% of Copper Sulfate Pentahydrate. Is this enough to cause metal stains on a vinyl liner?
    18,000 gallon in ground vinyl pool. Sand filter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Metal stains from Brite Stix I think
    Once copper reaches about 0.3 ppm it can stain pools, hair, fingernails, dogs, swimsuits, etc. What is worse is that the only way to remove it is to partial drain and refill. Copper is not good for pools. I don't understand why they make copper products.
