Thread: Hi from Oviedo, Fl
    Jun 2016
    Oviedo, FL
    1
    Hi from Oviedo, Fl
    Hi, and thanks for the add. We've had our pool for 10 years but only discovered TFP when researching a pump problem. I see that several folks have commented about the Marathon company's problems and I guess we're stuck with a malfunctioning controller. Thankfully, the pump still works, but only at high speed. Otherwise, our pool has had the usual problems and I've replaced various control panels, timers, salt generators, etc. Seems more malfunctions than usual, but have at least been able to do most of it myself. Looking forward to cruising around the forums and picking up some tips!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hi from Oviedo, Fl
    Welcome to TFP
    enjoy cruising around, take a peak
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
