Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: New build starting in Sugar Land TX - super excited!
    Jun 2016
    Houston TX
    48
    Hi All,
    Our pool build starts on Thursday! We signed the contract in May, but it took a month to get the HOA approval. The excavators will be here on Thursday! The family is super excited, but a little apprehensive about the mess in the yard for the next 45-60 days!
    Our pool:
    80 perimeter
    Roughly 30x15 freeform
    400 sqft with 3.5-6' depth
    Tanning ledge with 2 bubblers
    Bench in deep end
    One 500W light
    325 sqft deck (attached to 100 sq ft existing patio)
    Raised beam on one side with 1 32" scupper (2x8' 6" high sections and 1x7' 12" high section with scupper)
    Travertine coping and acrylic deck
    Ultra UV sanitizer
    60% quartz interior w/ 7 yr warranty
    This will be our first in-ground pool (had an above ground a few years back in our previous house), so it's pretty exciting! Hoping to learn from the veterans on here!
    Thanks.
    Ro
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New build starting in Sugar Land TX - super excited!
    Welcome to TFP
    Sounds like a very nice pool.. everyone loves Travertine, it really looks nice around a pool
    the pool builders in TX are really pushing back on salt water generators and pushing/selling UV systems, the problem is, they work great for indoor pools but you have the sun beating down on your pool so no need for more UV... Did they tell you that you would be able to use less chlorine with it?
    Grab a test kit now and test your tap water to see what you will be dealing with once you fill your pool and welcome to the addiction
    Jun 2016
    Houston TX
    48
    Thanks CowboyCasey. Yes, the PB claims it reduces chlorine usage by up to 50% and the water feels softer on skin. It was $800, so it seemed like a good deal. All 3 quotes I got had a recommendation for the UV unit, so I figured it was important!
    triptyx's Avatar
    Apr 2016
    1,438
    It's not important at all. Spend the $800 on something useful and/or fun!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Here's hoping your build will be the "Sugarland Express" heheh.
    looking forward to progress photos.
    +2 on ditching the UV unit.
    Dolphin E10 Cleaning Robot.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,215
    Hey Ro! Welcome to TFP. I can hear the excitement in your post - so much fun to read! This is a terrific site, and the experts and experienced people can answer anything!! If they don't know the answer themselves, they will find out or help you find the answer.
    The more you read on here you will see that those in the know recommend using basic supplies bought at local stores to keep the water safe and crystal clear. That means bleach from WalMart (or similar) for your chlorine to sanitize the water. Another option to get chlorine is by having a SWG or Salt Water Generator system that makes chlorine. Both are great with pros and cons for each. I have the SWG system. To keep your pH balanced, muriatic acid or borax will do the trick (grocery store or pool store). If you have a plaster finish (not a vinyl or fiberglass), you will want your calcium hardness level up to protect the plaster finish so it will last longer. CYA is another simple ingredient from amazon, WM, or Lowe's/Home Depot which protects your chlorine so it doesn't get used up so quickly when we have lots of sun. You don't need all the expensive multi-chemical powders and solutions the pool store will try to sell you. I just re-read your post and had forgotten you had an AG pool. You may know most of this stuff, but I'm leaving the notes just in case.....)
    I wouldn't bother at all with the UV unit. When you get a chance, you can begin reading here to find out more about keeping your water tip-top. The faster your build goes, the sooner you will want to read up on all of this. Others will be along to give you more specifics. I'm still a little new at all this! Lol!!!
    We'd love to see some pictures of your design and the before build of your yard. The more info we have, the more help we can be to you.
    Congrats on the new addition to the family!!!
    Suz
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jun 2016
    Houston TX
    48
    Thank you all for the welcome and the useful info. Will see if I can get the PB to switch out the UV for an LED light upgrade and some extra decking instead.
    will definitely post pics through the process. Hopefully things go well and at a fast pace!
    Jun 2016
    Houston TX
    48
    Design image:Attachment 50758
    Excavation began today!!Attachment 50759
    Aug 2014
    Houston tx
    2,524
    Let the mud begin!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jun 2016
    Houston TX
    48
    Re: New build starting in Sugar Land TX - super excited! - Pics
    Excavation is complete!
    Aug 2014
    Houston tx
    2,524
    Wow! What a neat job they did!
    Marla
    Jun 2016
    Houston TX
    48
    LOL.....the other side of the yard, just around the corner is DESTROYED!!!
    but overall, pretty happy with the quality of work so far.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Quote Originally Posted by goober71 View Post
    Yes, but just wait for the trenching/decking day(s). You may have to come up with stronger words.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    triptyx's Avatar
    Apr 2016
    1,438
    Don't "see if" the builder will do it, just demand it. Why pay for something that's useless!?!?
    Your shiny new hole is looking great so far! Best of luck on a fast and trouble-free build.
    Jun 2016
    Houston TX
    48
    Re: New build starting in Sugar Land TX - super excited! - Pic updates
    Steel and gunite were completed in the last few days. It rained a couple of hours after the gunite was completed, but the PB said that is actually good for it and helps it cure slower for good strength. Amazing how BIG the pool looks!
    Aug 2014
    Houston tx
    2,524
    Where are the pics???
    Marla
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    That is what I was looking for too! PICTURES please!
    You should be "bonding" with your pool twice a day aka watering it to help it cure slower.
    Kim
    Jun 2016
    Houston TX
    48
    so, it won't let me post any more pics tells me size limit has been reached! how do I upload more files?
    Jun 2016
    Houston TX
    48
    Steel and gunite pics.....I had to reduce the size and delete other pics to make room!
  20. Back To Top    #20
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    In order to post more pics you will want to either use a photo sharing website like photobucket or Flikr OR become a TFP Supporter which has other benefits as well. From the website click the Become a TFP Supporter at the top left.
