Results 1 to 12 of 12
Thread: Getting "keys to the pool" next week
    May 2016
    West Bloomfield, MI
    712
    I take possession of my new home/first pool a week from today. I had the pool inspected during the purchase process, but I haven't had a discussion with the seller.
    I think he's most comfortable with texts, so I plan to ask him some simple questions such as:
    - when was the last time he flushed the sand filter
    - if he plans to leave a test kit behind. If so what kind/what condition?
    - recent test results
    - name of his pool care company / supplier
    Do those make sense? Should I add or change any?
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Getting "keys to the pool" next week
    Congratulations!!
    - when was the last time he flushed the sand filter don't bother, just backwash (deep clean) yourself when you take possession. See article in Pool School
    - if he plans to leave a test kit behind. If so what kind/what condition? don't bother, just order your own so you can trust it TFTestkits.net
    - recent test results little to no value in his or pool store testing, unless this is a condition of the sale
    - name of his pool care company / supplier good question, but see below
    You don't mention the pool style or equipment. I would ask age or replacement of liner, pump, filter (and sand), etc. Just know, that he may be hesitant to tell you of any problems including his pool service. They may be more willing to share his struggles then he is.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2016
    West Bloomfield, MI
    712
    thanks PT. I'll order my own kit asap. I'll ask him for a referral and about the age of the sand. The pump is old and leaking, so I plan to replace it regardless.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    It doesn't matter how old the sand is because sand never goes bad. No reason to change the sand. However, you may have to deep clean the filter and inspect the laterals as mentioned by pool tool. But, you probably want to to know the age of the filter.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    May 2016
    West Bloomfield, MI
    712
    The filter pre-dates the previous owner. By the look of it, I wouldn't be surprised if it's original from 1972?
    May 2016
    West Bloomfield, MI
    712
    I just realized while reading some other threads that I don't know how to distinguish a sand filter from a DE filter by just looking at it, so I should stop sand until I know more.
    Based on the appearance of this relic, should I budget for a new filter?
    phenol red's Avatar
    May 2016
    Twin Cities, MN
    22
    Definitely whatever information you can get about the age of each of the components and the company that did the work will be helpful. We'll be able to tell immediately from your first valid test results how the water upkeep was.
    I just had a very similar situation with everything looking okay at first, but as soon as I did my own test, I found CYA levels over 200! If there are containers of 3" pucks like most people use, that is a definite possibility to watch out for!
    Quote Originally Posted by Rollercoastr View Post
    I'm not an expert on this but were DE filters even around in the 70s? Every DE filter I've seen has had the same two-part construction as a cartridge filter, with a top and a bottom connected by a radial clamp around the middle. I'm sure somebody else will be able to tell you exactly what make and model that beast is, though.
    30k gal in-ground, vinyl liner, Hayward 300 ft2 cartridge filter, 1 hp pump, Hayward 250k btu natural gas heater
    wjr75's Avatar
    Jun 2013
    IL
    836
    I received a folder that the owner who built our pool had. It had manuals, pool design prints, and permits that had been approved when the pool was built.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2016
    West Bloomfield, MI
    712
    Quote Originally Posted by wjr75 View Post
    That would be awesome, but probably too much to hope for in my case. This pool was built as part of the home and in fact, in the center of the home. There have been numerous owners and even a foreclosure. The seller has mentioned Leslie's, so maybe they have info to share.
    Ditto with mine. Only got me depressed to see that what I paid for my recent replaster was 2/3 the cost of the entire pool build 40 years ago.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    May 2016
    West Bloomfield, MI
    712
    I'm looking down that barrel too.
    Not a surprise though. When I first viewed the home, the pump was off and the pool was so cloudy I couldn't see the bottom. I asked for the pump to be running for the inspection, which revealed a leaking pump and a chipped floor surface.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Mine was a puck fed cloud too...cya 300 + (he told me to put 3 pucks in the skimmer every week!!)
    and the previous homeowner had used rubber radiator hoses with clamps for the filter....I asked him why
    he did that and not unions and he said "so the pump can be removed and serviced." LOL
    He also showed me how to backwash but never did the rinse cycle, when sand spewed in from the returns
    for a few seconds he said "that's normal."
    I would keep the sand filter you have.
    If any/all the equipment works, no need to waste money as I'm sure you'll be spending quite a bit for the move.
    Dolphin E10 Cleaning Robot.
