Thread: Pump gushing water..new pool owner
    Jun 2016
    Arizona
    3
    Good Morning All,
    Just bought an 18x48 Coleman pool. We noticed that when the water tubes fed the pump water, the tower/shaft would start to gush water out of the top. The output is open. The air purge valve is closed. When I turn the pump on, it would stop gushing and work normally. Tonight, we had a power outage and since the unit was off, it just started gushing.
    The o ring and purge seal is there, but it is still gushing....
    Any idea?
    Jun 2012
    western NY
    1,559
    Re: Pump gushing water..new pool owner
    Could you post some pictures of the pump? I am not too familiar with what those look like. Has the pump ever been apart? Is this a new or used unit? did it have to be assembled when purchased?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2016
    Arizona
    3
    Quote Originally Posted by danpik View Post
    Ive attached an image. Hope that worked. The pump came pre assembled and new with the pool box. It's space between the dark green ring and the grey dome that has water coming out before I turn on the pump. It works fine once the pump is on. The valve release nob (the little grey knob on top) makes no difference between open/closed.
    Jun 2012
    western NY
    1,559
    I am going to guess that you are missing a gasket under that lid.
    Jun 2016
    Arizona
    3
    You'd be correct. Solved the issue a few hours ago.
    Apr 2013
    Sacramento, CA
    2,769
    I agree with Dan. See if you can find a parts listing for the pump. I bet there is a gasket there.
