Results 1 to 9 of 9
Thread: A little advice? ...All too new to this...
    Jun 2016
    Media, PA
    3
    Hey all, I need a lottle help/advice. We recently bought a foreclosure property that came with an inground pool. This is our first pool. It's an inground, 25,000 gallon fiberglass pool. The water looked fairly clear when we peeked, but a lot of debri. After fully removing the cover and starting to clean all of that out...algae happened. I ordered the TF-100, but they were out of stock and its a 2-3 wk delivery period. I got some cheapie aqua chem strips...but as we figured...the pool basically has alnost nothing of anything. Everything came back very low on the strips.
    A little back story...the previous owner was sly and damaged things unseen (he actually cut all the electrical for the pool and pulled it out, and then put back 3 ft on each side so it looked like it was there!)...so we had unforseen circumstances hold all of this up, and we just really want to enjoy our pool!
    We'd like to start getting the ball rolling now rather that wait for the kit to get here... Any recommendations? Should I add CYA and try to raise pH with borax? Should I start adding chlorine, and if so, how much/often?
    I know it's a lot of unknowns...but if I could just do something to help now...even if its a *little* waste of say chlorine...I'd just really like to get something in motion here and maybe get this pool clear before it's time to close it
    Eve
    Funky Foreclosure
    25K gal, IG fiberglass, Hayward SP2607x10, Hayward c17502, AutoPilot SW
    G
    triptyx's Avatar
    Apr 2016
    1,438
    Re: A little advice? ...All too new to this...
    You don't know where you are with any of the chemicals, so for now, only consider adding concentrated, unscented liquid bleach until your kit arrives. An expert should be along shortly to talk about just how much they'd recommend you add each day.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Where did you order the TF-100 from? TFTestkits.net has it in stock always and will ship within 24 hours.
    Jun 2016
    Media, PA
    3
    I had to order from my phone and the TFT site would not display properly, so the only other place I could find was Pool Supply World.
    Last night I added 4lb of Stabilizer, and then after a few hours, added 8 jugs of the 128oz LA's totally awesome (2-3% weak) bleach based on PoolMath. That was the closest place I was able to make it to yesterday. Plan on picking up better bleach today. Anywho, this morning, our pool went from dark green with about 1 foot visibility to very light cloudy green.
    I tested with the strips just to see, and according to them:
    Total Hardness: Low
    Total Chlorine: OK
    Free Chlorine: OK
    Bromine: OK
    pH: Low
    Total Alkalinity: Very Low
    Stabilizer: Very Low (I know this one takes a while to show up)
    Should I try to balance my pH and alkalinity now? And how much chlorine should I add daily to try and keep it before my kit arrives?
    Eve
    Funky Foreclosure
    G
    Isaac-1's Avatar
    SW Louisiana
    6,711
    email Rebeca at tftestkits@gmail.com and she will get things taken care of for you so you can place your order
    Trying to clear that up with only test strips is an exercise in futility or will require massive over doses of chlorine causing potential pool / equipment damage
    DFW, TX
    24,504
    I have trouble seeing the site on my tab and phone also, choosing desktop version in your browser fixes it and then I can work through the site fine.
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Looks like a good old fashioned SLAM is in order. You may want to consider the "XL" option on your kit.
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jun 2016
    Media, PA
    3
    Eve
    Funky Foreclosure
    G
    triptyx's Avatar
    Apr 2016
    1,438
    That's night and day! Congrats!
