Thread: CYA Testing in the Sun
    Jul 2008
    Seacoast, NH
    250
    When I do the CYA test, back to the sun, sun over my shoulder, should the sun be shining through the side of the tube or should it be in the shade? I get 5-10 ppm lower if I hold it in the shade.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: CYA Testing in the Sun
    In the shade, back to the sun. Here are some reference pics, https://www.taylortechnologies.com/C...P?ContentID=36
    JoyfulNoise's Avatar
    May 2015
    13,201
    It should be held waist high in the shadow cast by your body. You fingers should pinch the top of the tube to hold it but do so with the least amount of the tube occluded by your fingers. Basically you want bright, indirect light shining into the tube. This produces the best result with minimal reflections.
    Matt
    Aug 2014
    Northern IL
    4,615
    Nice explanation, JFN. I would emphasize the shadow cast by your "body". My neighbor didn't hold it correctly and kept seeing the shadow of her "head" and thought it was the dot.
