Thread: Enable backwash on Easytouch?
    Oct 2015
    Windsor, ON
    12
    Hello all,
    I cleaned my cartridge filter today. The EasyTouch manual says I need to place the system into backwash mode to reset the fault in EasyTouch.
    My question is how to do that? I do not see an option within the panel / screen logic.
    I do have the backwash options configured, but I am not quite sure how to activate this mode.
    Appreciate your help!
    * I meant to place this into the Pool Pump area.. *
    16' x 34' Freeform Vinyl IG Pool, ~ 15,000 Gallons, Pentair Intelliflo VF 3HP, Pentair System:3 Cartrige Filter, Pentair Max E Therm 333 Gas Heater, Pentair IC40 SWG, Easytouch 8, Deck Jets, Intelibrite 5G Pool & Landscape, Built April 2016
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,545
    Re: Enable backwash on Easytouch?
    Something is not right.
    Please let us know what "Fault" does the EasyTouch say you have???
    Where in the manual does it say to "Place the system into the backwash mode"?
    I assume you pushed the Mode button and placed the system into the "service" mode and then cleaned your filter. One you put the filter back together, you should push the Mode button twice.. once to moves you into timeout and pushing it again moves you into the Auto mode.
    You can reset the system by pressing the "reset" button under the numbers 6 and 7 on the main panel.
    A puzzle to me..
