Results 1 to 8 of 8
Thread: 4th of July
    Jun 2014
    Houston, Texas
    475
    4th of July
    We will be having a party - i looked everywhere to post this but nothing seemed to fit.
    Anyway, the last time we had about 15, 20 teenagers in our pool, the water turned cloudy. I assume it was the sunscreen and lotions the kids had on.
    I want to avoid that this year. is there anything we should do ahead of time?
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: 4th of July
    Some people like to adjust their FC to the upper limit of normal so that it doesn't dip below the minimum.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: 4th of July
    Quote Originally Posted by DMS2014 View Post
    With all that natural aeration going on you should have no problem provided you're balanced going in. It's when they leave you should get busy to set up for the day after.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Wildcat's Avatar
    Jun 2013
    309
    Re: 4th of July
    Old thread mentions scum bug and keeping FC at upper normal levelhttp://www.troublefreepool.com/threa...screen-in-pool
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: 4th of July
    I always raise FC 3 or 4 ppm above normal before a party or big swim day. Then test after and raise it again. Always ready for the next day.
    Jun 2014
    Houston, Texas
    475
    Re: 4th of July
    I've never even heard of a scum bag. I just know I didn't care for the cloudy water once they all got in and then the sheen....
    19k SW IG
    DFW, TX
    24,485
    Re: 4th of July
    It is a floating thingamajig that absorbs oils off the surface of the water. I think it is called a scum-ball.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: 4th of July
    My last pool clouded up every time I had multiple guests but it wasn't a chlorine or lotion issue...it was a painted plaster
    and the paint was old....one of the best reasons never to paint a pool.
    My advice would be to brush the walls and floors and vacuum daily to the days leading up to the 4th.
    See how it looks after everyone's gone.
    Amazon has the scum-bug for a good price last I checked.
    Dolphin E10 Cleaning Robot.
