Thread: How should I be vacuuming to waste? Urgent request
    May 2015
    Huger, SC
    29
    Exclamation How should I be vacuuming to waste? Urgent request
    I have dead algae in the bottom of my pool that I want to vacuum to waste and I just used a flock. Everything worked and the junk is at the bottom of the pool. I set my multi port valve to waste, hook up my hose and vacuum as normal. I notice that water is going out the waste line as it should, but it also goes through the return back into the pool. I only have 1 return and the junk is getting back into the pool because of this. I marked this as urgent as I need to vacuum fully before the flock stops working.
    i have a ball valve on the hose going to the return and I tried closing it so no water would go through. The water then started to seep through the plastic site just before the waste port.
    what are the exact steps I should be doing in this situation?
    thanks ahead of time!
    Lucas * South Carolina * 18x33 Oval: 17000 Gallons * AG * Vinyl * Chlorine pucks / Floating Feeder * Well Water * Installed May 2014 * Hayward 18 inch - 150lbs Sand Filter * Hayward Power-flo Matrix Pump - 1.5 HP - 2 Speed * Standard Skimmer * Hayward Aqua Bug * TF-100 Water Test System
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: How should I be vacuuming to waste? Urgent request
    There is a problem with your mulitiport valve if it is letting water into the return path when it is set to waste. You probably have a bad spider gasket. For an immediate solution try vacuuming to waste by siphon method. Here are the instructions:
    Quote Originally Posted by madwil
    when I had a Intex, I used a standard vacuum head and hose, and set a syphon over the side instead of using the pump at all- as long as you don't mind watering the grass, and replacing water (same as vacuum to waste!)
    fill hose with water- start at one end, attach to vacuum to weight/hold underwater.
    push hose underwater along the length, so it fills entirely
    when you reach the other end, water should bubble out of it
    Hold both ends under water
    grab the middle of the hose, throw it over the side so a loop is hanging lower than the water level in the pool
    work back the length of the hose away from the vacuum head
    throw the end on the ground where you want the water to drain
    start to vacuum!
    when done, lift vacuum out of water to break suction, and drain to other end so gunk doesn't come back into pool
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Huger, SC
    29
    Quote Originally Posted by zea3 View Post
    I just bought a brand new head for my sand filter via Hayward. So is this defective then?
    when I vacuum to waste there should be no water going back through the return?
    ill try the siphon method as well!
    stevenmverrill's Avatar
    Nov 2015
    Frederick md
    30
    A quick solition could be vacume to filter then just clean(or back wash filter) till you get the gasket or what it may be fixed on the multi port.
    18x36 rectangle built early 90's, 9ft well, "black onyx" vinyl liner, 1 1/2" plumbing, 2 returns, 1 skim, 1 drain/return, plumbed chloranter, 48sf de filter, multi port valve, and 1.5hp jandy pump.
