Thread: Some Adjustments?
    r4m's Avatar
    Louisville/ Ohio
    40
    Some Adjustments?
    Not too bad but was wondering if I should start lowering PH and TA?
    I just added chlorine so it will actually be higher than what I recorded.
    thanks
    FC........3.5
    CC........0
    TC........3.5
    PH........7.8
    CH.......350
    TA......140
    CYA.....50
    27 ft round, 19,400, cartridge filter
    Jun 2014
    15,153
    Re: Some Adjustments?
    Not bad at all. TA & pH? ........ you could. Just focus more on the "consistency" of the pH though, holding better in the 7.5-7.8 zone, so that once you get TA where the pH doesn't rise too fast for your liking, then it's all good.
    Pool School - Lower Total Alkalinity
    phenol red's Avatar
    May 2016
    Twin Cities, MN
    22
    Quote Originally Posted by Texas Splash View Post
    Right - wait a few weeks to get an idea of how your pH drifts over time, and adjust TA as appropriate to counteract the drift. There's no need to adjust TA just to get the number right. I've found, especially since I use a solar cover that's on almost all the time, having a slightly higher TA than recommended helps keep my pH more stable - I haven't had to adjust pH for a month.
    30k gal in-ground, vinyl liner, Hayward 300 ft2 cartridge filter, 1 hp pump, Hayward 250k btu natural gas heater
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Quote Originally Posted by r4m View Post
    thanks
    FC........3.5
    CC........0
    TC........3.5
    PH........7.8
    CH.......350
    TA......140
    CYA.....50
    Looks good, but watch that FC. At 50ppm CYA, your minimum FC level is 4ppm, with a target of 6ppm.
    At your next CL addition, go a few ppm higher so the next time you check you don't dip below min.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    r4m's Avatar
    Louisville/ Ohio
    40
    Thanks everyone!
    PH is at 8 now
    Mar 2015
    South Texas
    411
    Thanks everyone!
    PH is at 8 now
    Use poolmath to figure out how much to lower it to 7.5 using Muriatic Acid
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
