Results 1 to 9 of 9
Thread: D. E. Filter help/question
    Mar 2013
    Central PA
    24
    Husband decided to open the pool for my girls yesterday when I was at work. Even after a text the day before telling him NOT to run the pump he did anyway. I had not put in any D.E. yet. The girls think he ran it for 1-2 hours. My water was crystal clear, and still is, so no algae to deal with.
    What do I do now? Do I take it apart and soak the fingers? Or do you think it will be okay?
    above ground steel pool, 13,500 gal
    Hayward Perflex EC50
    1.5 hp pump
    solar heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: D. E. Filter help/question
    Here is a handy tutorial on DE filters
    Use and care for DE filters
    Mar 2013
    Central PA
    24
    Yes, and thank you. I have already read that post. Unfortunately it does not answer my question as there is no mention of what to do if someone runs a de filter without any de.
    I see he has not been active on the forum for 2 year. Wish he was.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Since the water was clear it should be ok. You can open up the filter and inspect the fingers for any embedded debris. As long as they are not looking like a topiary project they should be fine. If they do have debris stuck in there clean it off as best you can. I doubt you would have much debris since the pool is clear.
    Love TFP? Become a
    TFP Supporter!
    Mar 2013
    Central PA
    24
    Thank you so very much! I was hoping it was okay but decided to take it apart to make sure. Now I am cleaning it. A few leaves and other small debris were churned up while they were swimming.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    While you have it apart check for tears and breaks in the fingers
    Mar 2013
    Central PA
    24
    Quote Originally Posted by Isaac-1 View Post
    I broke one finger. All the rest look good. Will that be a problem?
    May 2012
    Montville NJ
    545
    Quote Originally Posted by lne216 View Post
    Yes, with a broken finger you are going to get DE in the pool all day long. The good thing is, you can get a replacement finger quite cheaply. You can get them on line, or at the pool store. With a cracked finger, it will eventually tear the fabric covering, and then DE is going to go through that hole, and come out your return. You are going to constantly be vaccuming up DE from the pool, only to have it blow back in.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Mar 2013
    Central PA
    24
    Quote Originally Posted by phonedave View Post
    -dave
    oh boy. Thanks. I so wanted to put this together today.
