Thread: What does the rectangular white flat does in a skimmer box for above ground pool?
    May 2015
    Atlanta-GA-
    69
    Hi
    I am asking because the previous one was broken, it would not stay in place anymore, it seems the hinges were worn. So we ordered another and until it arrived ran the pool without one for 5 days. Nothing bad happened, so I wonder what that flat does?
    You can see it under water in the pic below.
    Thanks
    Pat
    12' AG, 3200GA, cartridge filter, pool installed 6/20/2015, Taylor K-2006 test kit,
    Feb 2011
    Portland, OR
    51
    Re: What does the rectangular white flat does in a skimmer box for above ground pool?
    It allows for debris floating on the surface to be removed from the pool more easily than without it, it keeps that debris in the skimmer basket area when the pump shuts off, and it prevents gulps of air from entering the pump and filter system while people are in the pool.
    10,000 gal Inground Fiberglass Pool;Aquarite SWG; Hayward H Series Gas Heater;
    Hayward Sand Filter; 1.5 HP Hayward Max-Flo VS Pump; Dolphin Pool Cleaner; TF100 Test Kit
    May 2015
    Atlanta-GA-
    69
    Thank-you very much for the detailed answer.
    Pat
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Yep, good answer suep! It is called a weir and it creates velocity at the water surface to create more efficient skimming of debris from the pool. Without it your skimming will become almost nonexistent.
