Thread: Will it damage my pool
    Jun 2007
    Kernersville, NC
    45
    Just a quick question about my ladder set up. I have a A frame ladder and i am having problems with it being to wobbly. Can i get it to sit on the top rail for added support if i use maybe some rubber. I was hoping that i can use the top rail as added support. Would this be ok I have 8 inch.resin top rails. Thanks for the input
    AGP (Wil-Par): 24' round, approx 14,000 gallon, 2 hp- 2 speed cartridge filter, TF100 test kit.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Will it damage my pool
    I had the same problem before I built my entrance deck, and the pool installation outfit I bought my pool from said not to do it, as you risk buckling the wall. I ended up building a simple frame using 4x4 posts with a 2x6 spanning between the posts, and attaching the ladder to the 2x6. I sunk the 4x4's in the ground about a foot, foot and a half deep, and just packed dirt around them, as I knew it was temporary and didn't want to set them in concrete.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
