Thread: Intex adapters - will these mate?
    Oct 2014
    Beaumont, CA
    47
    Can these 2 adapters mate? im wanting to use my Summer Escapes skimmer basket with an Intex sand filter using original Intex 1 threaded lines. So im wondering if the Intex adapter can clamp onto the Summer Escapes adapter?
    16x48 Summer Escapes Pro-Series Above Ground frame pool, 5000 gal, Intex sand filter - Looking for heating solutions for AGPs
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intex adapters - will these mate?
    it sure looks like it will work but I am not 100% positive..
    Oct 2014
    Beaumont, CA
    47
    the skimmer adapter is made for a slip-on type hose. Too bad they dont make a conversion hose all-in-one. I need an Intex threaded on one side and slip-on type on the other. Ill probably end up cutting 2 hoses and join them
    May 2014
    Corona, CA
    21
    Last year i did this mod to my summer escapes pool.
    Converting the Summer Escapes Pool Filter to Intex Filteration - YouTube
    Intex 14'x42"
    Intex 14" 2800gal sand filter pump
    Oct 2014
    Beaumont, CA
    47
    Yeah i saw that video. That is actually the ideal method but im not quite ready to hack away into the skimmer since the pool is already up.
    I did find that these 2 items can be made to mate up with very little effort. Summer Escapes skimmer adapter onto an Intex threaded hose. The OD of the skimmer adapter is a perfect match to the ID of the Intex hose. I just used a worm clamp and a smear of clear RTV to help seal. I chose RTV so i can separate in the future if i ever need to
