Thread: Hi From Ga
    Jun 2016
    Senoia, Ga
    26
    Hi From Ga
    Hi folks. Getting a 21'x52" doughboy above ground installed Thursday. Everytime I research maintenance I come across this site so I decided to register. As Im sure I will have a question at some point. I have owned a 15"x42" intex with a salt system in the past and this is a new pool with chlorine I am getting installed. I was told DoughBoy voids the warranty when a SWG is applied?
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Re: Hi From Ga
    We were told something similar. If we wanted salt, we had to go with a fiberglass shell. Ended up just going with chlorine. What kind of latter/steps did you order? Going to build a deck?
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Jun 2016
    Senoia, Ga
    26
    Re: Hi From Ga
    I am a deck builder part time...have built up around Smyrna, Marietta. So yes, I do plan to build a deck. They are giving us loaners that come with a $200 credit once returned towards new ones. So by then, I intend to have the deck built so I can get some meant for pools w/ decks.
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Re: Hi From Ga
    Nice! You will have to post some pictures when everything is setup.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Hi From Ga
    Welcome to TFP! Congrats on the new pool!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hi From Ga
    Welcome to the forum!
