Results 1 to 12 of 12
Thread: Need inground portable light suggestion
    Jun 2016
    27617
    5
    I have a 25,000 gallon inground gunite pool, kidney shaped. There is only one pool light on the deep end. The shallow end is too dark for nighttime swimming.
    Looking into portable LED lights because wiring to add real light is too costly.
    Any suggestions on what kind of portable light to add? Some of the magnetic ones seem to leak water inside the enclosure instantly thereby breaking the light. And not sure how well floating lights perform.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Need inground portable light suggestion
    I rather doubt you will be happy with most of the floating lights. Make that ALL of the floating lights.
    So look at this:
    Amazon.com : Smart Pool Mulitcolored Nightlighter for Above Ground Pools : Swimming Pool Lighting Products : Patio, Lawn Garden
    Ok its for Intex above ground pools. But it should work. You also have a cord on the deck. You may have to macGyver a way to hang it off the edge.
    Jun 2016
    27617
    5
    Quote Originally Posted by gwegan View Post
    So look at this:
    Yikes! $80 for a light that may still leak water into and have to figure out how to overhang. Can't believe no one is selling better solutions for quickly and cheaply adding lights to inground pools.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    My wife got the lights with the magnets for Intex pools from WalMart. We hang them in mesh bags weighed down with small river stones. Ours is an above ground and we have the bags' straps run through the coping clips. A permanent install in an in ground won't look good, but you can easily drop one or two in when you want to swim at night.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Jun 2016
    27617
    5
    Quote Originally Posted by RyanMcC View Post
    You mean the magnetic round lights with batteries? I read they leak water into the battery compartment easily and breaks it. Some have actually put them in ziploc bags before submerging in water. You haven't had any issues?
    Apr 2013
    Sacramento, CA
    2,769
    Remember functioning pool light and reasonable price are not in the same universe.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Quote Originally Posted by meanieme View Post
    We got the "GAME Remote control LED pool wall light" and yes, they're cheap. We just goop the seal with vaseline and it seals perfectly and you shouldn't have to open it to change batteries unless you're leaving it on all the time anyway. So while it's not perfect and it takes a bit of thought... once, it sure beats paying top dollar or hard wiring something!
    Inground pools by definition involve planning and usually include sufficient lighting so there's not a huge market for add-on lights. I have a kidney shaped pool with roughly the same capacity and a single light at the deep end. The light is plenty powerful enough to illuminate the entire pool. Are you sure there's no problem with your existing light? Have you looked into upgrading the lamp? Alternately, are you near the house and can you exterior flood lighting? My pool is about 12' from the back of the house and we have 2 old-style floodlight enclosures. I replaced the old floods with newer LEDs and it seems like it's 5 times brighter outside now.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jun 2016
    27617
    5
    Quote Originally Posted by Geebot View Post
    Here's a picture of my pool. I only have one light in the deep end and it doesn't light up far enough into the two shallow ends. I do have an exterior flood light, regular bulbs. What LED floodlights did you buy? I would like to try them to see if they are brighter.
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    When we bought our house the pool having no lights at all was a bit of a bummer. However, we did have a floodlight fixture of two bulbs each roughly at either end and found they did pretty well. VERY old and rusty and the fixture was ugly so I replaced the fixtures and also got the highest wattage dimmable LED floods Lowes had and changed the switch to a slide dimmer. The bulbs are daylight spectrum as well. We now rarely turn them up to even 50% and with them reaimed to be mostly at the pool it lights it up like daytime and spillover light enough for the rest of the enclosure as well without being over bearing. For sure at least give them a shot. Cheaper on the electric bill as well
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Jun 2016
    27617
    5
    What Flood Light LED wattage and do you remember exactly which one? Seems my best route now is to upgrade my floodlights.
    Mar 2015
    380
    Mine are Sylvania LED17/PAR38/DIM/850/FL40/W
    17W 5000K
    Scott
