Thread: green won't go away
    Aug 2015
    wooster/ohio
    2
    green won't go away
    Opened 5/28. Pool was dark green, almost black. (photo).pool store (bioguard) had me add "sick pool", shock, balance pal 100 (25 lbs), algaecide. after a couple of days, pool was a light teal. Always cloudy. (photo). We also swept pool. Backwashed several times, cleaned filter, etc. Pool started to turn more green. added more shock. 10 bags over a 24 hour period over weekend. (today is Monday). (photo) Have never been able to see bottom of shallow end. All of the shock as faded print on liner. FC 4, TC 4, combined chlorine 0, PH 7.6, TA 120, TA ADJ 90, Calcium hardness 190, CYA 90, Phosphates 2500. (note: These results were yesterday afternoon from litehouse, not where i usually go. The only place that was open on a Sunday. Bioguard store doesn't check phosphates. Just a selling point for more chemicals? I don't know what to do next.
    IG/ Vinyl, DE purex triton fnsp 36, 22440 gal
    Sep 2015
    Rome, NY
    363
    Re: green won't go away
    did you read Pool School (see my signature)?
    I'm a newbie, but suggest you ensure CYA is accurate (after dissolved for 24 hours) and then get another set of results.
    SLAM according to the chart....keep posting also.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    First, step away from the pool store. Their purpose is to drain your wallet and they have succeeded so far. Our methods are economical and rely on you to do your own testing and adding plain bleach to kill the algae and other simple cheap ingredients to balance the water.
    Second, order one of the recommended test kits, the TF-100 is the best value and you will probably need the XL option.
    Third, add 1 jug of plain bleach a day until your kit arrives. Go purchase several jugs of Wal-Mart great value 8.25% (found in the laundry section) or their 10% liquid chlorine (found in the pool/seasonal section).
    Fourth, read up on pool school.
    Fifth, post up your results after you get your kit. If your CYA is above 100, do a dilution of 50% pool water 50% tap water so we can get an accurate measure of your CYA.
    With all of the magic potions from the pool store, your pool probably has a CYA level that is too high. FC (Free chlorine) kills algae, but with a very high CYA, the FC is overstabilized and is unable to kill anything. Take a look at the chlorine / cya chart in my signature.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Aug 2015
    wooster/ohio
    2
    Yes, the CYA has continued to climb as I have added more chemicals. Also, when we took the pool pump apart to clean the filters, we found there was a crack in the manifold. Replacement of this part should help in the filtering process. Reading up on pool school. Will update in a couple of days. I will check the cya on chart. I do feel it is too high. It normally is 25 to 30.
    Aug 2014
    Northern IL
    4,615
    When you get a recommended testkit, you will know for sure what your CYA is. Then we can get you fixed up. That's what we do!
