Results 1 to 18 of 18
Thread: advise on -good Auto Vacuum for 22' Intex Pool
    Jun 2014
    WV
    5
    Question advise on -good Auto Vacuum for 22' Intex Pool
    Hi,
    i have a 22' Intex and have been maually vacuuming for little over 2 years now. now im looking for sugestions on side port auto cleaners.
    Thank you
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: advise on -good Auto Vacuum for 22' Intex Pool
    This is the one I have, very happy with it...
    https://www.amazon.com/Pentair-36010...+shark+cleaner
    But you will have a lot of choices depending on the amount of money you want to spend
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2015
    Stockholm, Sweden
    250
    Intex Auto Cleaner: at $50 can't be beat for value for money. Requires a strong enough pump, at least 1500gph.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2014
    WV
    5
    Thank You, yes i have a Intex 2800 Sand filter
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    This is the one I have. Love it. They say these are not for Intex type pools (probably because the bottom edge is rounded where it meets the wall) but mine works fine.
    https://www.amazon.com/Hayward-Critt...words=aqua+bug
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jun 2015
    Tupelo Ms
    18
    I am torn between these 2 choices that have already been mentioned the shark cleaner or the aqua bug decisions decisions.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    You can read some reviews in Amazon...
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    I'm extremely happy with my $50 Intex robot. I haven't cleaned my pool manually even once so far this year.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    After reading all the different posts yesterday, I jumped off the edge and purchased a Intex 3000GPH sand filter, Haywayd skimmer, and the Intex robot last night. All from Amazon, and total of about $260.. Gonna be a fun weekend! LOL!!
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    Aug 2015
    Tuttle Ok
    30
    Quote Originally Posted by pitguy3 View Post
    If you are using the Intex hoses, You will need one of these adapters to hook up the intex hose to the Hayward skimmer.
    Amazon.com : GAME 4560 40mm to 1 1/2 Inch Conversion Kit (For Intex Garden
    14'X42'' Summer Escapes AGP
    2800 GPH Intex Pump with Hayward S166T Sand FIlter and Krystal Clear SWG
    TF-100 Test Kit w/K-1766 Salt Test and Speedstir
    Jun 2015
    Tupelo Ms
    18
    Just ordered the aqua critter it will be here Friday thanks amazon prime
    Quote Originally Posted by brunnesa View Post
    This isn't true -- you can cut the end flange off one of the intex hoses and it will glue into a standard 1 1/2 PVC slip fitting available at the hardware store with a threaded male fitting on the other side. This will thread right into the bottom of the skimmer.
    Under Construction - Coleman 18' x 48" Above Ground Pool (6200 gal)
    Intex Krystal Clear Sand Filter Pump, 14", 2800 GPH
    Sioux City, IA
    Aug 2015
    Tuttle Ok
    30
    Good to know. I have not seen one hooked up like that before.
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Quote Originally Posted by cubsno1 View Post
    Please post some pictures of this being done.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jun 2013
    Seguin TX
    192
    Please note the Intex pool cleaner does NOT hookup to the suction side, it is a pressure "return" side cleaner.
    I for one own both the Intex pool cleaner and the Aquabug cleaner, I do NOT like the Intex, the Aqubug does a much better job and it is a skimmer side cleaner.
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Jun 2014
    WV
    5
    Thank You for the replies
    KazzyK810's Avatar
    Jul 2016
    Davison, Michigan
    75
    Just adding my recommendation for the aqua bug style of cleaner for an intex pool. I have Wanda the whale and she does a great job cleaning my 18ft round ultra frame.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Another vote for Sharky. Pricey but well worth it. Plus, he looks friendly. My kids call him Bruce, like the shark from Finding Nemo.
    Amazon.com : Pentair 360100 Kreepy Krauly Lil Shark Above Ground Pool Cleaner : Patio, Lawn Garden
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
