Results 1 to 15 of 15
Thread: Can't get my water sparkling...
    May 2016
    Cookeville Tn
    17
    I have been working since opening in Late April trying to get the pool sparkling and am not having any luck. So here are my numbers taken this morning. with the daily test kit my ph 7.5, chlorine 5; using the Taylor 100 my chlorine 6.5, calcium hardness 75, total alkalinity 80, cya 40. My circuit board tells me my salt level is 3500, the Taylor 1766 kits says 3000 and I also tested using AquaCheck salt strip and got a reading of 3000 - 3100 (the first line below the number 6 on the bottle). My water is cloudy and the liner is beginning to be dis colored.
    I have. 16' x 32' inground vynal liner, 20,000 gal. Sand filter and Hayward Swg. Replaced original circuit board at the beginning of the season with an after market board.
    Any suggestions? I normally don't have this much problem getting the pool up and going, with sparkling water.
    Hi, I am located in Middle TN area, have a 16' x 32' vynal liner, in ground pool and am using a T-9 Hayward Salt Generator system.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Can't get my water sparkling...
    Have you done an OCLT? Pool School - Perform the Overnight FC Loss Test (OCLT) If your water is cloudy, a SLAM is probably the solution. Pool School - SLAM - Shock Level And Maintain
    I had to SLAM this spring and it took a week of 24/7 filtering to get my pool from "clear" to "really clear".
    May 2016
    Cookeville Tn
    17
    Thanks. I have not done an OCLT, but will do that tonight. I'm new here and not sure I understand all about SLAMMING. (I read the Pool School info/instructions on doing it.) Is a Slam kinda like "shocking" if you are using Chlorine? It sounds much more in depth than any shocks I ever done when I used Chlorine.
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Read the links she gave. However, I think it helped ME, and others I have since gotten on board here, to learn that "Shock" is a process and not a product. True, many pool products sell things called "shock", but even those are a process even if as simple as "Guess and Pray". The "S" in SLAM, is indeed Shock, but is a process of shocking it. It's also not as complicated as it appears, but it may need to be read a few times
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    I live very close to you! After you make sure your pool is free from any algae, you might want to bring your CYA up per the CYA/Chlorine chart for SWG in Pool School. I keep my CYA about 75 - 80 and maintain chlorine levels accordingly. I have followed TFP since we built the pool and have never had any problems.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by Patcoomer View Post
    SLAMMING is using the CYA reading to find out what FC level will kill the algae. You maintain that level of FC by testing and adding chlorine to stay there until you meet all three criteria for ending the SLAM:
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    And the water is clear.
    It helps to read a few threads where people are going through the process so you will know what to expect. Of course, every pool is different, but it gives you a good idea. It seems daunting at first, but isn't so bad as long as you have the proper test kit. (Which I think you mentioned you had the TF100, correct?)
    May 2016
    Cookeville Tn
    17
    Thanks for all the suggestions.
    I just checked chlorine level, 2.5- down from 6.5 this morning. Can't do OCLT tonight I guess. Should I superchlorinate with SWG and add Clorox tonight or what?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    You could still do an OCLT, it tells you if you need to SLAM, even if your water is mostly clear. Sorry I didn't answer in time to do it tonight. (Unless you are still up, lol.) If you have to slam, you'll want to turn off the SWG (you need to for the OCLT for sure) and solely use the bleach.
    May 2016
    Cookeville Tn
    17
    👍 Thanks.
    @ksnewman 😊 Thanks
    May 2016
    Cookeville Tn
    17
    I did the OCLT last night. Did not pass.
    My CYA is 40. The chart starts at 60 and shows 24 as the level one would need to be to kill algae. Is there a formula to use to determine level of chlorine needed fora 40 CYA?
    Thank you all for your help. I am not a happy pool owner when my water isn't clear and sparkling...
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    For SLAMs, you pretend you don't have a SWG, so just use the top chart for now. After you are done with your SLAM, raise your CYA up to 70-80 and use the other chart.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Cookeville Tn
    17
    Thanks for the quick response! I appreciate it.
    I am curious about using Alum instead of DE to help with the clean up. Several years ago I had a Chemist friend who had a pool and he recommended using alum to help "seal" the sand so it would pick up finer particles of whatever it picks up. Is there a reason why alum should not be used?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Most around here will tell you that it is not necessary. 99% of the time that is true. If you pass OCLT and have no CC for many days and still aren't able to get the water filtered clear, that is the time to even start thinking about it.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I just did a deep clean of my sand filter. It improved the filtration immensely. This is how dirty the sand was, even though I properly back washed according to the guidelines. (When the pressure was 20% above " normal".)
    May 2016
    Cookeville Tn
    17
    @PAGIRL, Mr Bruce, ksnewman, needmoresun
    Hi again. I have been slamming my pool for the last three days. Last night and this morning my chlorine levels - 16 last night, 15.5 this morning and my cc is 0, the water is "clear"(not the crystal, sparkly clear that I want, but clear). My Cya is at 40. So, my question is do I add stabilizer to bring my CYA level up to around 70-80 now and when do I turn my Swg back on?
    Thanks for all your great help.
    I plan on doing a deep clean on my filter one day next week. The sand is about 4 yrs old and never done anything but backwash and rinse as needed.
